Question about Jura Capresso 560 Electric Burr Grinder
Do the ball bearings in a Capresso Infinity grinder go on top of the springs or between them?
I just took mine apart. The ball bearings go on top of the springs.
Posted on Jan 29, 2011
  • 1 more comment
  • Sean Nov 25, 2011
    This makes it official... almost anything is on the internet.
    Just the verification I needed! Thanks.
  • Odette
    Odette Jan 20, 2014
    thank you so much for this. I took mine apart and did not know where to put the bearings.
  • Frank C
    Frank C Apr 18, 2015
    How do you take the housing off? There are NO screws.
Simonelli Microbar ii the grinder positions change settings every time make a coffee grinder mooving positions automaticaly
First, I'm not a Simonelli technician. Though I've worked on similar table top machines.
* The grinder on these small machines (compared to commercial units) are usually manually adjusted. They are usually built with a range from very fine Turkish coffee (like talcum powder) to a fairly fine auto drip grind. You should not be able to coarse it up as used in a french press.
* There should be some sort of indexing to indicate at least the direction to rotate the grind adjust, say; fine to coarse, or even Turkish to American, etc. Though it may be a generic + to -.
* There may be a positive 'click' to each setting or possible hold down lock mechanism. But the most common is a spring loaded nub that clicks into place. If yours did click before and not now then you need to take it in for service as you probably lost the part (tiny ball and spring)
* A thought; If your an "Americano" drinker (course grounds will hot water filtered through it to fill a Mug size cup) then it may have happened when adjusting to the larger grind size. The indexer ball and spring is only held down by the height of the grind ring. Exceeding the largest grind will allow the ball and spring to pop out of position which can fall into the burrs and destroy them. It may be possible the ball (steel ball bearing) is still trapped in the burr plates and moves them around. Can't grind steel.
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Jan 18, 2018 | Coffee Makers & Espresso Machines
Grinder stopped working today. Tried to clean with no result. Anything I can do to trouble shoot? The timer goes, but no grind...
check to see if the grinder is jammed. Most likely, there was something that's gotten caught in it, and jammed the mechanism.
Feb 27, 2016 | Jura Capresso Capresso Infinity Conical...
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
How do I take my Imressa E8 apart?
Remove water container and empty beans. BE SURE UNIT IS UNPLUGGED.First, facing the unit, take out the three black torx screws from the bottom front. It makes removing the sides a little easier. Next, open the top lids, beans and water, and find the black pan screws in the top front and remove. Now, facing the rear of the maker, there are four screws disguised as buttons. Clamp on to the steel with a linesman pliers or you may need a side cutters. If using a side cutters, apply just enough pressure to grip and not cut. Remove screws counterclockwise. The top cover should lift up at this time. The side panels slide back to unhook from bottom and must be manipulated to release from front face. The side panel nearest bean grinder seems to remove a little easier than the water side. At this point, you may be able to clean bean grinder chute without further disassembly. If you need to service bean grinder, right side panel needs to be removed. Then remove the stainless torx screw holding on the bean cover to the grinding chamber. Adjust knob to full coarse setting. Next, find the two black torx screws inset in the bean container, probably have beans stuck above them. Remove bin. Do NOT remove the stainless torx screw on the top of grinder worm (on top of grinder blade)! From the side of unit, make note of clear and black wires on bottom of grinder motor so that wires will be put back on same terminals (can't remember if it was a dc motor). Remove wires. Make a mark on gear teeth of fine/coarse gear and gear ring of grinder to retain calibration. Now remove three stainless torx screws holding in grinder ***'y. Grinder ***'y should come out. Cleaning is easier at point. If you are to go further into the disassembly of the grinder, care should be taken because there are small springs and ball bearings in the ring gear and cutter.
Dec 26, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
I received a new lower burr grinder part from SAECO for my machine but no instructions on how to replace it. I know how to clean and replace the removable grinder part that fits into this. Do you have...
Hi
If you only got the lower burr it won't work. They should be matching burrs.
If you don't do it right, you will damage the grinder. You need a #10 Torex bit.
Insert the bit into the screw in the middle of a very clean grinder. Turn clockwise to loosen. Once the screw is out, pull the burr out, but be careful. There are ball bearings and springs under the burr. Make sure that everything is clean before reassembly. There are 3 holes in the bottom of the grinder. The springs go into the holes first. Then the ball bearings set on top of the springs. Place the new lower burr on top of the springs. A washer and the corkscrew go in next. Insert the screw in and with the bit in place turn (with a little down force) clockwise until the screw drops into place, then turn counterclockwise. It should turn fairly easy. Once you start putting pressure on the springs, try to turn the corkscrew. There is a notch that it slips into in the bottom of the grinder. Once it locks into place keep turning the screw until you start to turn the burr. That should be tight enough. Now reassemble the top burr and adjust.
May 12, 2010 | Saeco Vienna SuperAutomatica Coffee...
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
How do you remove stones from the grinder of a jura capresso E9 machine?
Disassembly of the grinder is most likely due. There are springs and ball bearings in there so be careful not to lose any parts. I learned that the hard way. I can send a pictorial, written in German, but helpful. e-mail me at mykr@yahoo.com.
Mike
Mar 02, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Blade installed upside down
I did this, too. Tell your M-i-L not to feel bad--it's an easy mistake. A Torx T20 driver will remove the center screw. However, when you remove the rotating blade, 3 springs and 3 bearings will come flying out. I'm not sure what order they go in when you reassemble the grinder. I reassembled the unit, and ever since it has not been able to grind the coffee quite as fine as I would like. Have not been able to find any info, such as an exploded parts diagram, to tell me the proper assembly.
Jan 14, 2009 | Jura Capresso 560 Electric Burr Grinder
Jura Capresso 560 Electric Burr Grinder Logo
1,897 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
