Question about Whirlpool Microwave Ovens
I have a model GH5184XP microwave oven, My wife tried to change the lightbulbs on it with the power on. both bulb broke. I got home and turned the power of to get the bulbs out. and then replaced them. and turned the power back on. Micro did not work. I then replaced the fuse behind the control panel. and turned power back on still does not work. Wondering what else could be wrong with it
  • 11,800 Answers
When the bulbs broke the wires from the filaments touched, shorting the power source - it got fried. The oven must be dismantled and the power source fixed.
I must warn you - the power source also delivers the power for the magnetron, and its voltage is in excess of 5000 . If you even graze the contacts for it you will be killed on the spot so if you aren't absolutely sure you can do it safely then either take the oven to a repair shop (it will cost you around $150 to fix it) or just junk it and get a new one.
Posted on Oct 01, 2010
How do I change the light bulb in my whirlpool microwave model # gh5184xp?
That's covered in your owner's manual.
If for some reason, you don't have yours, you can download it free here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 22, 2011 | Whirlpool GH5184XPQ Microwave Oven
HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
May 28, 2010 | Viking VMOR205SS Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Need to change the Cooktop light on a GE JVM1441. The directions say "After breaking the seal, remove the bulb by gently turning." To what seal are they referring and where do I find it. All I see is a...
Just gone through it myself. Wife was trying to change the bulbs and broke them both leaving the screw part stuck inside. I took the whole bottom panel off. It is 5 screws and comes completely off the microwave. Makes things much easier access
Jul 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
