Question about Citoh Computers & Internet
We have a c-itoh 105s printer and it prints tags from a foxbase pro software program. The user inputted an incorrect number of tags to print and now it is printing hundreds of tags. We have disconnected the printer cable as well as the power and when plugged back in the pritner continues to print. Is there a way to reset the printer from the printer itself. There are no print jobs sitting in windows. Help! Thank you.
SOURCE: Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
Posted on May 15, 2007
CompuGuy44
  • 432 Answers
SOURCE: ??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Posted on Jul 01, 2007
  • 18 Answers
SOURCE: Intermec 3400 label printer
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Posted on Sep 06, 2007
MUKHTAR
  • 2022 Answers
SOURCE: Jobs stuck in the print queue for hp 2410xi all-in-one
just go to run and type services.msc and press enter it go to services option select print spooler and stop it and then run it will remove all the pending job and ready for print new job.
let me know if you stuck anywhere bye.
Posted on Dec 03, 2007
SOURCE: failed response from plugin device
Dirty fix...
When the printer errors out...stop, unplug the power to the printserver. Reset the printer, Clear the print que (delete jobs/restart print spooling service), restart the printserver software and plug the printserver power back in. Wait for the re-detect. Everthing should be good at this point. Unfortunatly the print job will be lost and you need to print again...BUT, NO REBOOT yea!!!
Note... for me, if this sequence is not followed, I will have to reboot. The printserver will be locked for the PC that was trying to print. All other PC's will be fine, and I have no idea why.
Good luck,
Bill
Posted on Jul 01, 2009
Printing barcode + overwriting RFID tag
no most bar codes will print out but it must be printed in black and wite as for changing the barcode no you have to download a special program that lets you make bar codes. not sure how though
Jun 17, 2013 | Office Equipment & Supplies
Sample of how to create a python program that will input two numbers and will ask the user of operation to perform as to addition,subtraction,multiplication or division the program should perform the...
Assuming that the input numbers are given by the user:print "Menu"print "1. Addition"print "2. Subtraction"print "3. Multiplication"print "4. Division"print "0. Quit"
a = input("Please make a selection:")if a == 1: x = input("Please enter a number:") y = input("Please enter another number:") answer = x + yprint "%r plus %r = %r" % (x,y,answer)elif a == 2: x = input("Please enter a number:") y = input("Please enter another number:") answer = x - yprint "%r minus %r = %r" % (x,y,answer)
The same goes for everything else just with different signs. Don't forget that "*" is multiplication and "/" is division. Also, for 0. Just use:
elif a == 0: quit
Sep 28, 2011 | Computers & Internet
Please help. Printer not printing. Urgently...!!!
Sounds like you chose print to file for the port in the driver instead of what it should be set for. comm for serial cables. lpt1 for parallel, usb for usb. by having it set the way you do it is told to save the code. goto printers and faxes and right click on the zdesigner print driver and chose properties. then click the ports tab and chose the correct port.
Jul 02, 2009 | Zebra S4M Thermal Label Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Red qoutation light keeps blinking/a440 print dock
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Office Equipment & Supplies
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
Bad driver?
courput print drivers or not the exact drivers.
Jan 15, 2008 | Zebra 105SL Thermal Label Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printing from different trays
this can normaly be solved by going into the printer preferences and then setting the trays manualy in the software. otherwise the printer will automaticaly select the main tray first then move onto the mp tray. sorry if it sounds a bit vague but these options change from printer to printer and have not seen a k850 for a while Hope thyis helps Cops Pete@wedotoners.com
Aug 16, 2007 | HP Officejet Pro K850 InkJet Printer
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Computers & Internet Logo
27 people viewed this question
Top Citoh Computers & Internet Experts
David Payne
David Payne
Are you a Citoh Computer and Internet Expert? Answer questions, earn points and help others
