Question about HP Pavilion a1330n (EL466AA) PC Desktop
I tried replacing my sata drive in my hp pavilion a1330n with my ide drive that was from my hp pavilion a510n. When i boot up the a1330n with the ide drive i get a blue screen saying that it has shut down windows but when i put it into my a510n it works fine. Can any one help me?
    Sergeant:
    Champion:
  • 305 Answers
Yes the 2 computers are different. Different processors, different memory,different graphics card.To get your ide drive from your hp pavilion a510n to work in your hp pavilion a1330n, you will have to completely re-load the drive when it is installed in the hp pavilion 1330n. Then it will work fine, but you will not be able to use that drive in your hp pavilion a510n. because you will have the same problem but in reverse.
Posted on Oct 01, 2010
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
Do I need sata or eide for internal dvd writer on HP a1330n?
This model HP has a SATA disk controller.
You need a SATA DVD writer.
If you are not sure, when you remove the faulty DVD writer, take it with you when you go to purchase a nre DVD writer, make sure the new DVD writer has the same connectors as the faulty DVD writer.
Jan 22, 2012 | HP Pavilion Media Center a1330n - AMD...
HP HP Pavilion dv2000 no display
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Oct 18, 2011 | HP Pavilion dv2000t Notebook
My hard drive died in my HP pavilion 9795c. I replaced the hard drive, inserted the recovery cd and it says error loading operating system. I used a full version of xp pro with the same result. In setup...
I would suggest you pull the new hard drive out to make sure you've got the jumpers set correctly. Match them up with what you had on the old drive. Master / Slave / CS (cable select)
Once that's corrected you should be able to boot into the recovery cd so long as you set the boot options up correction in the bios.
Let me know if you get stuck.
Jan 22, 2011 | HP Pavilion 9795C PC Desktop
I recently had a hard drive failure on my HP Pavilion a610n. I decided to replace the IDE drive with an SATA drive. However, the computer will not recognize the SATA drive. I have tried plugging the SATA...
I'm not sure you can insert your OS disk to istall or not, so the solution depends on your being able to do so. It seems to me there's a strong possibility that the BIOS cannot see the drive because that software had basic drivers to recognise the IDE Drive the computer came with.
So, you have to locate the SATA Driver which can be loaded during installation of the OS from either a boot cd or boot floppy. WIndows Setup gives you a chance at the beginning of setup if you watch the progress bar below to press F6 if you need to load a "Third Party or RAID driver" A little further along the setup will stop and prompt you for this driver and you'll need it ready with the exterior CD drive or floppy drive attached with the media in it to load.
It's quite possible this is what you're going to have to do. If this isn't the solution, please don't trash my rating with a thumbs down click. I'm trying to help without complete info.
Best Wishes
Aug 03, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
Problem replacing sata drive with eide drive in HP A1330n
if hard drive show in the bios setting and not loading the window then your hard drive not work properly.change your hard drive.
Jan 16, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
A1430N Moved my two working ide drive 250G over
Hello
Thank you for using
FixYa for your problem
IDE will try to boot first when pluged in, sata will not boot. I think there is a adjustment in the BIOS setting to have the SATA boot first
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
Computer will not boot
Hello.
If your computer will not boot try to first boot your hard drive in the BIOS. Make sure that the hard drive are inserted correctly replace the power cable in your hard drive also the SATA or IDE cable.
Regards
ICmanServer
Jul 31, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
DVD Rom Drawer
This is a sure sign that the drive is faulty or the ide connection. Try a different ide connector from the other ide cable in your computer if you are able.
Feb 04, 2007 | HP Pavilion a1330n (EL466AA) PC Desktop
HP Pavilion a1330n (EL466AA) PC Desktop Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
