Question about Whirlpool Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
    Problem Solver:
  • 6 Answers
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Posted on Oct 02, 2010
Tip
Dryer Dry Time Appears to Jump or Stall During Auto Dry Cycles
The operation of dryers during the Auto Dry Cycles is based on the moisture content of the clothes as they cycle over the moisture sensor. At the start of the cycle, the default estimated time is displayed depending on the cycle selected. The moisture sensor feeds information to the control based on the "wetness' of the clothes during the first 5 minutes of the cycle. The control then calculates and display a new estimated time making the time appear to "jump".
Recalculation happens again based on the reduction in the "wetness" of the clothes when the Estimated Time Remaining is between 15 to 5 minutes. The control will extend the cycle and display the Estimated Time Remaining unchanged if it "sees" no significant reduction in the wetness level of the clothes. The dryer will run longer than initially projected and give the appearance that the displayed time has "stalled".
Clean the sensor bars for any films or dirt build up to make sure it sends accurate information to the control. Level the dryer front to back and side to side to ensure the clothing will tumble properly and making good and proper contact with the moisture sensor bars. Check the dryer vent duct for any restriction to ensure a good air flow as the operation of the Auto Dry Cycles is based primarily on the air flow condition.
It is highly recommended to clean the lint filter before every load and make sure the dryer is grounded at the wall plug.
on May 17, 2010 | Whirlpool WED9200SQ Electric Dryer
Why is my dryer not heating?
The heating controller may have failed.
Jul 28, 2014 | Whirlpool Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
I recently had the heating element replaced on my whirlpool electric dryer model #LE5800XSW3. Prior to replacement, clothes dried completely in one cycle. After replacement the clothes take at least two...
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Jan 22, 2011 | Whirlpool Dryers
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
348 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
