Question about Sewing Machines
I changed my needle on my singer 3116 and the needle threader does not work anymore. Hope you have an answer! Thanks!
    Genius:
  • 1,788 Answers
It is probably out of alignment, just turn your needle threader so that the little wire goes through the eye of the needle and will catch thread. Also, sometimes the needle you put in has too small of a hole to thread easily with the automatic needle threader.
Posted on Oct 05, 2010
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
Auto Needle Threader Won't Come Down
If it's still in warranty, send it in for repair. If it's not still in warranty, pull out a length of top thread and clip off the end with sharp scissors at an angle. Poke the end of the thread through the needle eye -- it should go through easily. Two second solution.
Jan 09, 2014 | Singer 3116 Simple
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
Automatic needle threader stuck in lower position
So sorry I don't have an automatic threader so I'm no help in this department. Good luck!
Oct 26, 2011 | Singer 3116 Simple
I own a singer simple sewing machine
By threading part, do you mean the automatic threader? I've never had much luck with them. Yes, you can thread the needle manually.
Happy Sewing!
Feb 04, 2010 | Singer 3116 Simple
Self threader won't work
the needle should be in the up position or the threader won't come down, still when it does, you have to get the thread right across the hole in the needle for it to catch,
another problem is that you bent or broke the center pin that pulls the thread through the needle,
the tip that comes to the needle has three parts, the two outer ones that wrap around the needle and the center pin that goes through the hole in the needle,
If this is bent you may be able to bend it back if broke you need to get it replaced
take a good magnifier and take a look at the center pin!
Hope this helps
moni
Sep 06, 2009 | Singer 3116 Simple
Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Apr 11, 2009 | Singer Sewing Machines
Singer 3116 - change the needle
I'm giving you a direct link to the Manual on page 82 of which is explained the procedure of removing the needles so you can attach new ones the same way...
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lemme know if it helps :-)
Feb 12, 2009 | Singer 3116 Simple
Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Feb 07, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
274 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
