Question about Garden
2003 craftsman dgt 6000 27hp need to know how to put on the blade drive belt need a diagram or walk through process
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 376 Answers
SOURCE: diagram for drive belt
Her's a link to your manual... Page 23.. http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0712426.pdf
Posted on May 27, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
Dusterz
  • 46 Answers
SOURCE: belt diagram how to put the engine blade belt on a
parts and diagrams for assemblies
Posted on Jun 12, 2010
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
I need diagram to thread blade drive belt.
Route the deck drive belt between the two inner, forward pulleys and then out and around the outer blade pulleys.
Jul 30, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a belt diagram for the mower deck on a Craftsman DGT 4000 mower w/ 48" deck... Can you help??
If you go to sears.com and click on parts. You will need to enter your model number-not dyt4000-but the model number on the machine's ID plate, probably with the serial number.
It will respond with your mower parts diagram!
May 07, 2011 | Craftsman Garden
Belt diagram for a Craftsman 42" riding lawn mower
there are as many belt diagrams as there are mowers. You will need your model number to get the correct diagram. You should find this under the seat or on the very back of the unit. sorry can't help more at this time, when you get this, you can get online and go to sears and you will find it there.
Sep 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Belt routing diagram
On link below on page 9 will show you the belt diagram.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L1001239.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 22, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Having trouble replacing a 42 craftsman riding mower belt...help Ithe old one broke off but the new one it on too tight...the replacement one is the right lenght help please
do you remember the routing of the belt? there should be a diagram on the deck somewhere - best thing to do is rout the belt while the deck is lowered, leaving the loop at the front to put around drive pully on bottom of engine. once that is all hooked up, there are deck adjusters on either side of the deck - that you can adjust to relieve some of the tension on the belt - turn the adjusters clockwise to tighten, counterclockwise to loosen - let me know if this helps or if u need more info - i have a 10 year old 42" deck tractor out in my barn and if need be, tomorrow i will walk u through - online how to adjust the deck
Sep 06, 2009 | Craftsman Garden
Putting all belts on
look at the guard for the blades, the diagram routing is drawn there , u may have to loose a nut or 2 to get ot out of the drive pulley
May 22, 2009 | Craftsman Garden
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
I need to put a blade belt back on my Craftsman yard tractor
If you disengage the Blades like you normally would, this will give you plenty of slack in the belt to put back on. There should be a pulley or lever that tensions the belt when it is engaged and that is what is causing it to be too tight to put back on. Hope this helps
Apr 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
954 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
