La labadora no llena agua - Washing Machines
  • mayarafael97 Oct 01, 2010
    the washer start ok but dont fill water
  • 5,081 Answers
Can you please post your question in English so that we can understand it and help you...
Posted on Oct 01, 2010
  • 1 more comment
  • INDIRA KUMAR
    INDIRA KUMAR Oct 01, 2010
    Your problem might be the same mine was.
    1. Turn off both water faucets
    2. Carefully remove the hoses (one at a time)
    3. Remove and clean the screens at both ends
    4. Re-attach the hoses
    5. Turn on the water
  • INDIRA KUMAR
    Have you tried to fill both cold and hot water..
  • INDIRA KUMAR
    Have you tried to fill both cold and hot water..?
Hola mi lavadora no se llena con el agua? el agua est? encendido y conectado correctamente. la luz est? encendida, donde hay un s?mbolo de la llave, ¿es este el problema? ¿C?mo puedo apagar el indicador?...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 12, 2015 | Televison & Video
Mi labadora liquea agua por abajo junto al motor.
my front load leaks water from the side does any body know what the problem. thanks
Mar 10, 2013 | Kenmore Elite 45986 Front Load Washer
Mi suzuki aereo tira agua de la manguera superior por la union de la abrasadera y el radiador,es como si no pasara el agua y se incha mucho la manguera, ya le cambie la bomba de agua q estaba desconpuesta...
Si la manguera sufrio dilatacion por efectos de temperatura, es mejor cambiarla; efectue un purgado del sistema, para eliminar aire en el interior del sistema de enfriamiento. Verifique los niveles de refrigerante.
Apr 23, 2012 | 2003 Suzuki Aerio
Como debo controlar el bote de agua ? en cuantos grados centigrados debo ponerlo para un mejor funcionamiento
No es necesario a?adir agua al tanque de aire acondicionado port?til. Cuando la unidad funciona, se genera es el agua de la condesation en la habitaci?n. La adici?n de agua, significa que usted tendr? que darin el tanque con m?s frecuencia.
Espero que esto
te ayud? y gracias por elegir FixYa.
Sep 22, 2011 | LG LP1200DXR Portable Air Conditioner
Tengo una camioneta jeep grand cherokee, 97 que en la computadora me manda un mensage, coolant sensor bad y no lo e podido corregir y sale mas cuando hace mucho calor
Ese es un mensaje comun en este tipo de camionetas; tengo una '93 GC Limited 5.2L V8 y presento el mismo problema por algun tiempo.
Solamente hay dos cosas por hacer:
1. Desconecta el harness del sensor y dale una lavada con solvente dielectrico para contactos electricos. Previamente desconecta los bornes de la bateria.
2. En caso de que el procedimiento anterior no funcione, podriamos pensar que el sensor de refrigerante es el que esta da?ado, enviando una falsa se?al al VIC (Vehicle Information Center) que es el que te envia el fallo.
OJO que cuando desconectas los bornes de la bateria el ECU se resetea, con lo cual podriamos tambien probar que era un error antiguo almacenado.
Aqui hay un tema en una web Jeepera de Espa?a: http://www.jeepy4x4.com/foro/viewtopic.php?p=311758
Espero que esto te sea de ayuda; recuerda calificar esta respuesta. Suerte.
Oct 05, 2010 | 1996 Jeep Grand Cherokee
User manual for LG fuzzy logic 7.5Kg
Buenos dias mi lavaora es una fuzzy logic 7.5 lg cuando lavo me sale DE y la e palpita varias veces la lavadora prende normal llena agua pero cuando comeinza a lavar sale las letras a ver si me puedes apoya por favor
Sep 27, 2010 | Washing Machines
2000 chevrolet express 4.3 con problema de rendimiento de gasolin
El código P0410 es el sistema de emisiones. La bomba de aire pone de aire para los gases de escape para reducir las emisiones. Lleva en el aire exterior y la bombea a través de dos válvulas de retención de un solo sentido en cada banco de los gases de escape.
Alrededor del 90% del tiempo que este código se establece, las válvulas de retención de un solo sentido han llevado a cabo o no y permitir que el agua (que se produce naturalmente en los gases de escape) de nuevo en la bomba. Cuando el PCM comandos de la bomba, si la bomba está llena de agua que puede sobrecargar el circuito y se "destapa" el fusible.
tenga en cuenta que esto puede ser cubierto por la garantía de emisiones en el vehículo. Si su vehículo está fuera de garantía de parachoques a parachoques, comprobar si la garantía de emisiones, sigue siendo válido!
1. Vuelva a colocar la bomba de aire y una válvula de retención de vías
2. Pruebe y limpie la bomba del aire y de prueba y reemplazar el aire de un solo sentido válvula de retención
3. Vuelva a colocar la bomba de aire tubo de alimentación
4. Reemplace el fusible de la bomba AIR (que se encuentra debajo del capó)
Gracias por utilizar FixYa y buena suerte
Jul 21, 2010 | 2000 Chevrolet Express Cargo
Freezer door was slightly ajar overnight.now i can't get the freezer to cool even on power freeze.what should i do
What you will need to do is remove your food to another location. Unplug or turn the unit off for at least 24 hours. What has happened is the coils have become clogged with ice. Once you let it melt out it should work fine. You may end up with some water on the floor. Leave the doors opened and lights should be unscrewed so they do not stay on. And take care.
Thanks for asking.
May 22, 2010 | Samsung RM255LASH Side by Side...
Tengo un refrigerador GE gs6shaxks01 y no frabricando hielo...que hago/
CAMBIALE LA VALVULA D AGUA O EL ICE MAKER. VALVULA DEL AGUA ESTA ATRAS DEL REFRI. EN LA PARTE DE ABAJO SIGUE LA LINE DE AGUA. EMPIEZA POR LO MAS BARATO. NO TE VA A COSTAR MUCHO.( LA VALVULA) SUERTE. DEJA TU COMENTARIO SI TE SIRVIO ESTE PEQUENO CONSEJO GRACIAS
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Tengo una lavadora LXR7144EZ1 Empezo con un ruido
Mil gracias por tu ayuda, la lavadora cuando llena no hace ningun ruido, luego cuando empieza a restregar empieza un ruido fuerte y despues de esto se detiene por completo, muchas veces a trata de llegar al ciclo de exprimido. Pero el dia de ayer dejo de funcionar completamente.
Sep 01, 2009 | Whirlpool Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
