Question about Kenmore Washing Machines
My Kenmore model # 11029522800 shakes and walks around like crazy when on spin cycle, Larry
  • Kenmore Master
  • 3,740 Answers
Hi Larry, Welcome to FixYa I am Kelly.
Stand in front of the machine and tip it so the back legs elevate about 1 inch off the ground and drop it. The rear legs are floating / self adjusting and this is the standard leveling technique. If after you perform this leveling process your washer is still walking during spin there can be suspension pad problems. (Items 13 and 15 of this link) http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11029522800/0582/0153200/K0810006/00006?blt=06&prst=&shdMod=
Thanks for choosing FixYa.
Kelly
Posted on Oct 01, 2010
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
My Kenmore when in spin cycle it shakes all over the floor rattling and shaking
I can't offer a definitive answer but I have had a little experience.
It is possible it is spinning too fast. The brain of the machine needs to know how fast the motor is spinning in order to control the speed. The motor is fitted with a tachometer sender for this purpose. It is important any replacement motor is fitted with an identical tachometer to the original.
The brain is programmed to cycle the spin slowly at first at increasing speeds to allow the washload to settle and for most of the water to be removed so when full speed is reached there will be less vibration. Perhaps the cycle is incomplete or absent and it is starting on a high speed spin...
The washtub suspension can become worn and weak even though it appears intact...
It is conceivable the drum is imbalanced - a drum that is nicely balanced will not vibrate when spinning without a washload.
Dec 27, 2017 | Kenmore Washing Machines
WTW4800xq0 shake bad during spin cycle
My washer was just doing the same thing shaking like crazy on spinning cycle whirlpool model WTW4800xq0 I just change the 4 suspension spring balancer rods part #W10820048 and it work like new againg search amazon cheaper than sears easy to change I hope this help some body and save money this parts cost $50 dollars on amazon
Dec 01, 2012 | Whirlpool Washing Machines
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
While replacing motor coupling and vigorously moving motor gearbox around, something dropping on the base of drum but could not see what it was. And after completing the motor coupling job , I set the...
those pins are not important they are there for transportation purposes such as moving from one home to another or country don't worry about them. As far as the shaking and walking use a level and level your machine in both directions.
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
Apr 07, 2017 | Washing Machines
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
167 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
