Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Refrigerator (Model #20) w/freezer on the bottom
The temperature in the freezer is getting warmer. Have had it set at 5 degrees, it is currently 25 degrees. The refrigerator is cooling fine. The motor is running constantly and there is a loud buzzing noise. This refrigerator is only 18 months old!
  • 3 more comments
  • orkycowboy Aug 23, 2008
    We are having the same problem, but our's is a side by side refrigerator. We do not have the loud buzzing noise, but the freezer and fridge are both running, but getting warmer instead of colder.
    Could you please describe what the condensor looks like.
  • Jack E Legs Jan 11, 2009
    I have similar problem. Freezer set at zero, but only cold to 22 degrees. I do not have an ice build up.
  • Anonymous Feb 10, 2009
    same problem, paid >$200 to have it diagnosed and now after 2 months, the same thing has happened. GE Profile (bottom freezer). Very disappointed with this and will not buy again.
  • Anonymous Feb 21, 2009
    The refrigerator seems to have stopped. Temperature is getting warmer and termometers are not working. What T Do?
  • Anonymous Mar 17, 2014
    THE REFRIGERATOR LOGS OUT AT JUST UNDER 40 DEGREES. THE FREEZER IS LOGGING OUT AT NEGATIVE 15 DEGREES. I HAVE THE TEMP SETTINGS RIGHT IN THE MIDDLE.
    Problem Solver:
  • 13 Answers
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
  • 828 Answers
In back of the unit is a removable panel. Remove this panel and check the condenser for some kind of obstruction, such as paper sucked into the fan. Clean the condenser by blowing out with air or vacuum cleaning it. Reinstall the panel after you are done. The loud buzzing noise. Where is it coming from? If it is coming from the compressor behind that back panel. Normally the temperature problem is reversed from how you stated.
Posted on May 26, 2008
GE bottom freezer PF22missaww i came home from vacation and it was at 60 degrees , unplugged it for 10 minutes and plugged it back in , ran fine for a month , came home from work and the unit is warm again...
GE Profile bottom freezer erratic.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which may have reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 13, 2017 | Refrigerators
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
The GE Profile PDS22sfsarss is now 4 1/2 years old. One year ago, the temperature panel stopped working and a repair person told me to just order that circuit -- which I did and replaced it myself....
Not certain this will help your situation, but here is what I did to mine.
3. Plugged it in (which probably reset the electronic controls.)
Jun 11, 2017 | GE Profile PDS20SFS Bottom Freezer...
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
1,415 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
