Question about HP Computers & Internet
Printer does not respond when trying to print documents and have to keep installing the program
    Novelist:
    Scholar:
  • 134 Answers
Need more info.. 'keep installing' what program..? Has the printer worked correctly in the past? Does the printer work with any other 'program'? Does the printer work from notepad? What operating system are you using? What brand & model of printer is it? Can you install the printer to another pc & test it there? Can you run a printer 'self test'? Thats where you do not have the printer connected to the pc, but hold down some buttons on the printer, to force a self test, to prove the printer actually prints. You can also run a printer test from the operating system.. Eg if you are running windows XP, go 'start button', 'printers & faxes', right mouse click the icon for your default printer, select properties. You should see a button to self test.
When installing usb connected devices..
It's a common mistake to connect the USB cable to your pc
before installing the software. If thats the case, it's probably
the reason why it will not install.
In the past, I have had to disconnect the usb cable, un-install the
the software (sometimes the un-install software is on the CD)
then re-install the software/driver, then when the install software
prompts, plug in the usb.. Or if it does not prompt you to connect
the usb, do so at the end of the software/driver installation. That
is, after you have booted the pc.
Rgds,
dave
Posted on May 26, 2008
    Scholar:
  • 139 Answers
Open the printer folder and right click on it then cilck on use printer online n ur done.
if u r using windows, click on start then on printers and faxes u'll see list of printers there. right click on the printer u r using then click on use printer online
thank u
I am printing documents to my HP LaserJet 5000n Printer and the printer's not responding. I've tried restarting it and it displays that it's processing a job before displays that it's ready.
Either a corrupted driver or possibly a bad network card or parallel port, depending on how you have it connected. Does the printer print test pages from the on printer control panel ok? If yes, try printing a different document from a different program or try the windows test print from the driver. If it prints the windows test print then likely you have either a corrupted program or file. If it will not print the windows test print then I would delete the driver, download the current HP UPD driver and install that.
Sep 24, 2015 | HP LaserJet 5000n Printer
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
Aug 14, 2011 | Dell 946 All-In-One InkJet Printer
Printer is not responding
see ther will be 2 cause of problem 1 is may be the printer driver is not proprly installed or may be check the printer cable also.
make sure when you switch on the printer it start normally without any error on display screen.
Sep 09, 2009 | Office Equipment & Supplies
Need Dell All-in-One printer 924 to work with Inspiron 530S.
If it doesn't say it is specifically for VISTA then it is not for VISTA.. Even if it does show up on the computer ,that just shows that some driver for that model printer is installed. Not necessary one that will work. Go to the weblink that I gave you. Download the VISTA drive and update the driver, using the one you downloaded ,and that will most lkely fix the problem.
Mar 03, 2009 | Dell 924 All-in-One InkJet Printer
Dx 4000 - keeps trying to print same document; can't delete it
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP PSC 1510 All-In-One-Printer not responding
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printer is not printing at all
You may not install the correct driver for the correct OS. Not sure what OS you are using but below link might be useful for you to get the correct driver and install into your PC.
http://etech.maiila.com/hp-deskjet-3845-driver-manual-software-download-and-troubleshooting-tips
Hope this helps
Nov 13, 2008 | HP Deskjet 3845 InkJet Printer
Printer won't respond
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Jun 29, 2008 | Epson Stylus C62 InkJet Printer
Keep Printed Documents
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
Dec 19, 2007 | Brother HL 5140 Laser Printer
Computers & Internet Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
