Question about Brother MFC-5440CN All-In-One InkJet Printer
Can't clean. Called tech support had me do some things and ended up with Error 46 and to bring into authorized dealer. Any ideas on what's wrong. Thanks
Cant print,Unable to clean,how can I solve the problem
Posted on Oct 05, 2010
How can't i get relay 12vdc for sharp microwave model r658ls
that parts available only to some authorized serv. tech. company . there might be some serv. company near ur area repairing that parts. f ur a technician pull out that relay to serve as a sample and bring to some part dealers
Sep 27, 2014 | Sharp Microwave Ovens
2002 escalade service stability system. Is there a quick fix w/o a dealer checking it out?
Any high end scanner will be able to access the system. It dosen't have to be a dealer.
Jan 10, 2011 | 2002 Cadillac Escalade
I am facing the problem of clean unable 46 and clean unable Af please give me solution
The error message "Clean Unable 46" is an indication that the machines ink absorbers are full or almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Clean Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Dec 17, 2010 | Brother MFC-290C Printer
Troubleshooting item 46
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
check the brother website for an authorized service center in you're area.
Jul 13, 2010 | Brother DCP-135C Flatbed Digital MFC...
Unable to clean refer to maintenance guide 46
Hi
Thanks for using FixYa. Printer error 46 indicates that the ink absorber pad is full and required to be replaced by an authorized engineer. To resolve the issue please contact Brother Customer Service from "Contact Us" on their website—
Error 46 solution
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error-46
Machine error 46 ("Unable to Clean") indicates the wasteink "sponge" as full, which disables the machine's ability to clean. To fix this, you could get the needed part from a Brother parts dealer and enter the servicemode to reset the counters. However, the more reasonable thing to do would be to just change to another machine. You could also have the machine sent to service, but that most likely would not be worth the trouble. The error is pretty common on old Brother inkjets, so it'll come back eventually even if you replace the part. Newer machines should not have this problem.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother 2820 power supply
YOU MIGHT TRY GOING ON THE WEBB AND TYPE IN PARTS FOR BROTHER MACHINES. ONLY BROTHER SERVICE CENTERS THAT ARE AUTHORIZED CAN ORDER FROM BROTHER. GOOD LUCK BROTHER SR TECH
Dec 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Error message cannot clean
search error 46 (waistink absorber needs replacing)
Feb 25, 2008 | Brother MFC 420CN All-In-One InkJet...
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
83 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
