Question about LG HBM-310 Bluetooth Headset
It will not pair up with my phone no matter what 4 numbers i put in with my hbm-310
    President:
  • 1,118 Answers
You must put your headset in pairing mode first. Starting with it turnedd off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the GMB-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them with each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Hope you are able to sort your problems out soon.
Regards, Carlos
Posted on Oct 01, 2010
I am looking for a manual for the LG HBM-310
http://www.lg.com/uk/mobile-phones/mobile-phone-accessories/LG-bluetooth-headsets-HBM-310.jsp
On the right side you can download the manual
Mar 02, 2011 | LG HBM-310 Bluetooth Headset
How do i pair this bluetooth
you must put the device into pairing or discovery mode then search or add new device from your phone menu once they have discovered or paired you will need a 4 digit pin or pairing code ,Most blue tooth device manufactures use the following codes 0000,1234,1111,or 9999 i hope this helps
Feb 20, 2011 | LG HBM-310 Bluetooth Headset
LG HBM 310 will not connect to to my new Blackberry 9550. I am entering 0000 as required.
You must put your headset in pairing mode first. Starting with it turned off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Please, let me know if I can help you any further.
Regards, Carlos
Nov 17, 2010 | LG HBM-310 Bluetooth Headset
I CAN'T SEEM TO PAIR MY BLUETOOTH.IGET A MESSEGE PAIRING FAILED
Regards, Carlos
Aug 10, 2010 | LG HBM-310 Bluetooth Headset
I have a LG HBM-310 and I do Not have a passkey can you help
It's '0000' (four zeros). If you need further details on how to pair it with your phone, you must put your headset in pairing mode first. Starting with it turned off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Regards, Carlos
Jun 15, 2010 | Apple iPod touch
Pass key mssing
Regards, Carlos
May 06, 2010 | LG HBM-310 Bluetooth Headset
I need the numeric passkey for the LG-310
Regards, Carlos
Dec 29, 2009 | LG HBM-310 Bluetooth Headset
I lost instructions on how to pair my lg bluetooth hbm 310 to my cell phone and my phone is asking for a passkey where do I find it on my blur tooth?
You must put your headset in pairing mode first. Starting with it turnedd off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Regards, Carlos
Nov 01, 2009 | LG HBM-310 Bluetooth Headset
How do you put the LG earpiece in pairing mode???
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
Oct 11, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM-310 Bluetooth Headset  Logo
240 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
