Question about JVC LT-42E488 Television
Need to reset factory setting .and would like to learn how to upgrade software.
My luxor flatscreen tv. Dtv option has been removed ive lost dtv anyone know how to get my dtv back on my tv ?????
factory reset in main menu/system.settings, if you are connected to the internet try software firmware upgrade also. ....but factory reset and new set up should do the trick.
Aug 08, 2014 | Televison & Video
Tip
How to reset opera back to factory default setting (Profile reset)
The basic steps are 1)Backup necessary files 2)Delete opera6(configuration settings) file from profile directory. See details below.
What is profile reset?
Profile reset removes all your preference settings(like the options you choose in tools>preferences,custom toolbars,menu etc) and let opera rebuild it to the factory default condition automatically. The great advantage it brings that it destroys bad settings that you might have done or might have accumulated with multiple upgrade etc. This is very likely to resolve many issues users encountered with opera user settings.
What to do before profile reset? Do I need to backup?
You need to backup your files so that you can get back your data.
How to do the profile reset?
Close opera. You need to locate your profile directory (Help>about opera will show you the exact location). In windows xp, it is commonly at c:\documents&settings>username>application data>opera>opera>profile and in win vista its under in Win Vista C:\Users\yourname\AppData\Roaming\Opera. Note that "Application data" is a hidden folder in windows and you need to enable the opton to view hidden files and folders(open my computer>tools>folder options>view>show hidden files and folders). Once you have found the folder, just find and delete the file opera6.ini(configuration settings). Restart opera and opera will rebuild the profile settings.
on Nov 19, 2013 | Opera Software Browser
Unlock password
You will have to reset it factory settings
Performing factory data reset ( master reset or hard reset ) Sony Xperia J ST26i/ST26a via Settings menu:
To perform a factory data reset
From your Home screen, tap Applications
tap Settings
tap Backup & reset
tap Factory data reset
tap Reset phone.
tap Erase everything.
Jun 07, 2013 | Sony xperia j st26i black unlocked gsm...
The tv speakers are turned off, i just want to know how do i turn them back on-I get no sound at all
Tries cable or satalite boxes and tv unplug,replug it back like about an hour later.For the tv resetting itself back to the factory setting and those pay boxes to reboot and upgrade the their softwares.Go into the tv menu goto Audio Setting,go down do a resetting to the audio setting back to the factory setting.By doing these steps,tv audio have a great chances of returning.
Aug 11, 2011 | Mitsubishi LT-52153 LCD TV
Tv is on but no sound. Its not muted and volume is turned up
Tries tv and those cables or dishes boxes unplug,replug it back like about an hour later.For those pay boxes to reboot and upgrading it softwares.The tv to do a whole tv set resetting it self back to the factory setting.Than go into the tv Menu Setting to go to the tv Audio Setting.Go down to do a audio resetting again for the Audio Setting to go back to factory setting.These steps will help and have a great chances to get ur tv audio back.
Jun 25, 2011 | Olevia LT32HVM 32 in. LCD Television
I want to upgrade my LG gt540 from 1.6 to 2.1 or whatever, but the problem is that when i connect my my mobile to the pc they say that i already have the latest version. and i cant upgrade it (The Cell...
Ok Basically whats happening is that your phone is not recognizing that there is an android upgrade available, this is a bug in the software.
before performing a hard reset make sure that all your applications are upto date as they may interfere with the update process. once you update all your apps check the update screen again. through Settings -> About Phone -> System Updates
To perform a hardware reset goto
Settings -> Privacy -> factory reset
and follow the prompts.
your contact and paid application information will be saved on googles servers, remove your SD card to save pictures and videos before performing a reset.
there are free applications in the Android Market to back up text messages as well. Best of Luck.
Jun 15, 2011 | Cell Phones
I have an RCA L32HD31 32 in. Tv. I have a picture but no sound. It is less than 2 yrs old. Any solutions?
Tries tv and cables or satalites boxes unplug,replug it back like about an hour later by letting the tv resetting itself back to the factory setting those boxes upgrading it software.Now go into the tv Menu go to Audio Setting go down for a resetting back to the factory setting.By doing these steps,u have a great chances to get ur tv audio back.
Jun 07, 2011 | RCA L32HD31 32 in. LCD HDTV
3110c says phone memory full with only 575 contacts. I used to have 1500 contacts. Upgraded the firmware to latest version. How can I get the unit to accept the 2000 contacts it is originally designed to...
If your able to switch on your phone then try this
To reset your Nokia phone please follow this.
Press 3370#
It would reset the phone to factory settings.
The default code is 12345
or
If your phone is not starting please press these buttons simultaneously.
onoff + + 3
If still the problem persist scan your phone for any virus.Your phone is affected by virus.If stilll problem persist you have to flash your phone.
Jan 11, 2011 | Nokia 3110 Cellular Phone
Is it possible to do a factory reset on a CDJ1000? (pitch issue)
There is no mention of a factory reset in the Mk1 service manual. The firmware can be upgraded - Mk1 & Mk2's need to go to Pioneer / Videotec, Mk'3 can be upgraded from CD.
http://www.pioneer.co.uk/uk/support/software/CDJ-1000%20MK3/index.html
The pitch may just be faulty, look here for a replacement :-
http://stores.ebay.co.uk/methleykev
Jul 18, 2010 | Pioneer CDJ-1000 CD Player
My son changed the menu from English to Hebrew and can't change it back. Can someone help
Aside from learning hebrew, guess you could follow the step in the manual for changing the language 'blind' and try it that way
The easiest soloution is probably to do a factory reset, a factory reset will restore all the settings to thier original status ( make sure you back up any important data on your player, as data may be erased on the factory reset) this link will allow you to download the software to do that
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Jul 07, 2009 | SanDisk Sansa e250 MP3 Player
Televison & Video Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
