Question about NetGear Computers & Internet
I have three computers,on your rerouter, main one goes online but the other 2 do not
  • 33 Answers
Do Provide Further INFO
how are the Computers Connected ?
Ethernet or Wireless ?
Whos the ISp? what Modem?
Whats the IP address on all Computers ?
Posted on Oct 01, 2010
  • 65 Answers
I assume its wireless router setup ... only one pc is connected rest of other don need to hook up with anything else not even with main computer... but make sure you have wifi network card installed in your other machines ... then it will connect automatically, just hit the browser to connect internet an u will be all set!
    Scholar:
  • 88 Answers
Go to command
start - run- cmd and enter in the black window type ipconfig make sure all the other computer has the same ip address - only the last number can be different that no issue...
E 500 i - B1 Vizio, rarely used would not turn on. I had a professional replace the main board and the power board. Have lights but still No picture. Purchased in May 2014.
Your computer is three years old or more.
Most of the software on modern computers goes obsolete
after three years.
I suggest not spend a dime on it and instead purchase a new one.
Nov 02, 2017 | Televison & Video
Female coax connector broke on vizio smart t.v.can i buy an adapter or reroute out of cable box to t.v.
If the cable box has an HDMI or video output, use one of them to connect to the TV instead. The female coax connector is not easily repaired and you can't reroute or adapt anything to fix it. You will need to replace the TV main board if the HDMI/video connection is not an option.
May 05, 2017 | Vizio Televison & Video
The moment i start the fuse goes off changed nearly three fuses
probly the noise supressor capasitor folow mains lead into back of mechine u will have mains lead going into it 2 other going out of it to mech components good place 2 start good luck tom.
Sep 20, 2014 | Whirlpool duet Washing Machines
Dell 1908 FTP Monitor turns on and shows picture but in just a few seconds then goes black
check all connections. then separate the wiring so it doesn't touch. sometimes the cross-talk caused by wires touching can reroute the signals. good luck.
Jun 26, 2014 | Dell E173FP 17" LCD Monitor
I have no internet to my main computer i rerouted the cable from the router to my lap top then I have enternet but not on my main computer
First, make sure you have the internet cables on your main computer pressed in tightly (to computer and router).
Then carefully follow...
1) Unplug power cord or turn off the "cable modem" (first box that comes into your house provided by the cable company).
2) turn off your router (or unplug).
3) turn off your main computer
4) turn on (or plug in the power cord) for "cable modem" and allow it to run its startup route (1 minute minimum)
5) turn on (or plug in the power cord) for router and allow it to run its start up routine (1 minute minimum)
6) turn on your computer and let it start up and check if internet works.
good luck and rate me please.
May 04, 2011 | Computers & Internet
When turned on, monitor power light comes on for a moment and then goes out. Monitor eventually comes on after several minutes. The same happens if the monitor is left on but goes into sleep mode.
This is a common problem on these monitors. There are three or four capacitors in the power supply, three on the inverter board and anywhere from 2 to 6 on the main board that go bad.
The number on the main board depends on how long the monitor has been having problems before it was serviced. The longer the wait, the more capacitors will have gone bad.
The power and inverter boards are easy to repair, the main board is not. As mentioned, it is a multi layer board so removing the old capacitors and the old solder can be troublesome. I would suggest you have someone experienced at soldering repair the main board.
Btw, our shop would charge $60 labour plus $2 for each capacitor.
Dec 18, 2009 | ViewSonic VP2030b 20.1" LCD Monitor
Drainage problem
I had similar problem and rerouted the drain hose like papps54 said. I still had the condition and decided to pull out the drain hose completely to see if there was any debris trapped inside the hose. There was! I removed the hose from the machine completely, cleared out the debris, and let the hose soak in white vinegar overnight. In the meantime, I looked back up the drain outlet and found evidence of debris lodged in there as well. I didn't completely dismantle the dishwasher at this point but I did eventually clear it out as well as the drain filter located inside the dishwasher. After reassembling the drain hose and dishwasher, I cleaned it with baking soda for three nights and now it runs very well with no odors. Runs quieter as well.
Oct 10, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Monitor goes black
Kindly attach the screen to your another system or note pc. Else being a simple device it contains only three main parts.
1) Panel
2) Power supply + HVPS
3) Main board
need to be tested one by one.
Aug 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Sucessful rerouting does not give a website on internet explorer
go to run from start menu and type cmd and then type ping yahoo.com if you see the line of ip's of yahoo pinging so the is a connection if no check your network driver
Dec 27, 2008 | Microsoft Windows XP Professional With...
Hitachi 51F510
Same problem but mine goes black for long periods. Menu prompts still available and volume "meter" on screen is still visible. Have rerouted cable, changed outlets, all to no avail.
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
