Question about Singer Sewing Machines
Singer zig zag 387 threading guide - Singer Sewing Machines
  • 7 Answers
SOURCE: How do i set thread tension on a 306W Singer
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
Posted on May 06, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Posted on Aug 21, 2009
  • 2976 Answers
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
I am trying to replace monofilm panels in a windsurfing sail, using a Singer 457 zig zag sewing machine. I cannot create a good zig zag seam when the monofilm is sandwiched between two canvas layers.
Joe, you might try a larger needle than you're using. You might also want to try a larger leather needle. You machine should take needles up to a size 18.
It sounds like the needle you're using is having a problem picking up the bobbin thread, and that might solve it.
Mar 09, 2017 | Singer Sewing Machines
I have a Singer sewing machine model 9117. Every time I use the zig zag stitch the machine jams and I cannot continue sewing. Any ideas?
try a new needle
make sure the top thread has not come off the thread take up lever
there could be something wrong with the cam that does the zig zag stitch, if the problem continues you may need to have the machine checked
Apr 07, 2016 | Singer Sewing Machines
How to thread childs singer zig zag sewing machine
You didn't give the model name for the machine; however, if it's a Pixie or Pixie Plus, you can download the user's manual that shows you how to thread it and wind a bobbin from the Singer Sewing Machine site. The number listed above your question is not a legitimate model number; it might be a serial number.
Feb 01, 2015 | Singer Zig Zag 727198 Sewing Machine
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
I have a singer 4411 and the bottom thread looks zig zag and top is good I am using a heavier thread for outdoor sewing and a 18 needle. The local singer dealer said that i can get the lower bobbin...
Understanding Thread Tension Threads
Be sure to mark the tension screw setting on the bobbin BEFORE you make any adjustments so you can reverse the changes. If you sew a lot of heavy fabric, it may be worthwhile to buy an extra bobbin (they aren't that expensive). Then set one bobbin for heavy thread and keep one for regular thread. Makes it a lot easier to go from one to the other without fiddling with tension screw adjustments.
Feb 24, 2018 | Singer Sewing Machines
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Aug 20, 2009 | Sewing Machines
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Sewing Machines Logo
133 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
