Question about Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
10 yr old quiet plus series wont drain - Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 01, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Whirlpool Gold Quiet Wash Plus...model#gu940scgq2...about 15 years old...washes fine but now there are 2 buttons that do not work - air dry button (which is also the lock/unlock controls) and the...
Rich,
At 15 years old you are probably going to find that parts will be limited in availability and expensive if they are available. With buttons not working, that sounds like probably a controller problem and that would be an expensive part. You would probably be better off putting your money into replacing the dishwasher. The average lifespan on a dishwasher is anywhere from 7 to 10 years, so you have your money's worth out of that unit. Hope this helps!
Apr 07, 2015 | Whirlpool Dishwashers
Wont start, no lights on control panel,power is on
1 month old call maytag should have a warranty
Dec 13, 2009 | Dishwashers
Frigidaire Dishwasher won't drain
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 15, 2009 | Frigidaire Dishwashers
Leaking & icing on inside coil Rheem Air Conditioner
Dirty coil. Low refrigerant. Bad fan motor.
These 3 things cause the problem described.
I charge $450 to remove and clean the coil. However, I am not in your zipcode.
Jul 05, 2009 | Heating & Cooling
Maytag legacy series 3 yr's old
I had a similar problem where slowly specific buttons stop working. Moisture was getting into the control board and slowly killing buttons. I replaced the control board and that worked for another year, until the buttons began dying again.
For now, there are other ways to start the machine, but you just have to let time expire to stop it. It is probably a control board issue.
Dec 12, 2007 | Maytag MDB7100AWB Dishwasher
Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher Logo
170 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
