Question about Kenmore 64683 Microwave Oven
Kenmore Elite Microwave hood
My microwave comes up with F-9 when it has completed its cooking. The book has nothing with this in it. What is F-9.
  • Globaby May 28, 2008
    We also have the same problem and there is nothing in the book to explain the "F-9" which appears a few seconds once start is applied. But a nephew stated he found out it was a defect in the door latch but without a solution offeredin the handbook I'm still at a loss as to repairing it or replacing it with a new model. Thanks Gloria
    E-mail address is
    My model is 636693-- Elite ultra wave microwave Hood
  • Anonymous Jun 18, 2008
    i've been having the same problem? is it really the door hatch??? but in my case the door seems fine. I wonder what could it really having trouble deciding wether to get rid of it and get a new one. so please if anyone gets a solution, i might be able to save a couple of hundred bucks...thanks.
  • Kenmore Master
  • 9,098 Answers
Please reply back with your brand and full model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on May 26, 2008
How do I set the timer and use the cook function at the same time on my Kenmore microwave model 405
Either your microwave is defective or you don't understand how to use it. Try Googling (Kenmore)(74229)(manual) without parens to get instructions or go to for the same.
Sep 16, 2016 | Kenmore 74229 Elite Black Countertop...
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute. Plug it back in and see if the fault code returns. If it does, then you have an internal component failure that will need to be serviced by a technician. Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair
Aug 03, 2017 | Kenmore Microwave Ovens
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Kenmore 64683 Microwave Oven Logo
202 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
