Question about Delta Masonry Tools
The motor on my jointer was running fine then all of a sudden the RPM dropped drastically and had no power what-so-ever.
  • 4,234 Answers
I'm going to guess that this unit runs on 240V. I would first suspect that you lost one leg and only have 110V going to this unit.
Check that and update this with the model if not the case.
Thanks,
Dan
Posted on Oct 01, 2010
Why does my car's RPM goes down when idle and AC turned ON?
No idea here i would suggest a visit to the garage that installed the gas conversion ,if i had my head inside the engine i might be able to work out whats wrong but from afar ? i stand no chance
Aug 05, 2014 | Suzuki Swift Cars & Trucks
2003 nissan frontier stalls when i slam on the brakes
Check oil level, but might be idle motor going bad. The idle motor kicks down the idle as needed as the rpm dictates. If sudden reduction in rpm occurs the idle motor normally keeps up and motor continues running at reduced idle. Unless its going out on you, then you may experience stalling when speed is suddenly reduced such as hard braking.
Mar 16, 2013 | 2003 Nissan Frontier Crew Cab
I have a 2008 mercury Milan with nearly 60k miles on it. When I come to a stop the rpm drops by 1000 then recovers quickly. What should I do to fix the problem? Any suggestions will be greatly appreciated.
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode? http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces? http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
--------How to adjust rpm on 2009 dodge charger SRT8?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increases http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000? http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills? http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPM http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM? http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Driving on the road the RPM goes higher wituout speedind
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode?http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces?http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | 2008 Toyota Avalon
Jointer doesn't run smoothly
My bet is that the motor is designed for 220/240 (single or three phase), but you're running in on 110 single phase. If the belt were slipping it would sound like the belt on a car (you know when someone starts their car and belt is loose and goes "Sccrreeeeeee" until the rev the engine and make the belt catch up to the pully).
The power in wood working motors is such that it should be very difficult to slow down the motor if you're feeding at a slow rate. But, if the motor needs 220 and you're powering with 110, then the motor will have no power (the magnets in the motor are matched with the voltage - and if you have the wrong voltage you won't get any power and the speed will be very slow).
Typically the "home" or "residential" tools only run on 110, but if you have a larger unit they can be wired for 220 or 110. If you bought the planer used, they may have been running with 220 and now you're powering with 110 (or vice versa). I'd do a quick google search for your unit to see what it's capable of. Or, just take the model number of the motor (not the planer) and search for that.
Typically, motors can be run at 110 or 220 for larger wood working tools. Inside the metal housing where the wire feeds into are a number of wires to connect to. These wires have numbers on them (either a tag or printed on the wire insulation) and you attach them a certain way for 110 and a different way for 220. Sometimes you can even change the direction of the motor - SO BE CAREFULL IF YOU REWIRE IT! don't power it up all the way on the first try. Just start it and then stop it while the motor is still coming up to speed. While the planer is still spinning (even though the motor is off) feed your board in slowly and you'll be able to tell which way the motor is spinning. If you get the wrong direction on your motor you can shoot boards across the shop (or out into the street if you're in the garage - like I did).
Jun 23, 2012 | Delta JT160 Shopmaster 10 Amp 6 Inch...
More RPM Issues for Tools 1) Have old jointer with motor..1725rpm 5 1/2" pulley.. pulley on jointer is 2 1/2" ..what is 4" jointer blade speed ? also looking for right speed for 4" jointer.. 2)...
I had the same problem a while back, But I didn't bother with exact speed, what I cared more about was power and speed, and not bogging down. And I had it running smooth. Of course I have no idea what the pulley diameters were, but it sounds like you should be real close with the 2 1/2 inch at the head and 5 1/2 inch at the motor spinning 1725, should be about 900? So to get 700, bring the 5 1/2 down to 4 1/2, see if it has enough speed/power.
Feb 13, 2010 | Air Tools & Compressors
Need to wire for 220 power
Often, the 220 wiring diagram is on the back side of the plate that's screwed on the motor junction box. Or it is on the spec plate on the motor.
May 16, 2009 | Delta Machinery Delta 37-275X X SERIES 6"...
1990 gmc k2500 new 5.7engine & turbo 400 ,power lose & noise.
sounds as if you may be looking in the wrong spot. If different gearing is drastically changing the symptoms you may want to check the trans. or torque converter. sudden pop with engine rpm increase and lack of power sounds like possible band breakage in transmission or impellor breakage in torque converter.
Oct 20, 2008 | 1990 GMC K2500
How to Replace Drive Belt
Unplug the jointer. Invert it on a thick cloth to protect the blades and the work surface. Underneath you will see a base plate that covers the bottom and is held in place by seven screws. Remove all of the seven screws and set them aside with the baseplate. With the baseplate removed, you will see the power leads running to the main switch and back to the motor. Remove the hex bolts that hold the motor in place. There are two on one side of the motor (indicated by purple rectangles in the picture), and another one on the other side. Remove them completely to allow the motor sufficient room to move in order to place the drive belt over the motor spindle. If your hex key is not long enough for this job, hold the key in a pair of pliers or vice grip to remove them. (Now that the jointer is disassembled, this is a good time to clean all the motor housing thoroughly and lubricate, if applicable.) Lift and rotate the motor and attach the drive belt. The motor will not easily return to its normal position. In the picture you can see just how far the motor has been turned to get the drive belt on. Insert the hex bolts again, deep inside a very narrow space, whilst using a fair bit of force to hold the motor in place. This is the difficult part, and you may utter a few choice words at this point and consider some unauthorized modifications to the housing. With patience and persistence you should be able to secure the hex bolts once more and once again have an operational planer/jointer.
Aug 27, 2008 | Sunhill Machinery Mobile Base for 6"...
Masonry Tools Logo
73 people viewed this question
Top Delta Masonry Tools Experts
Vernon Taylor
Are you a Delta Masonry Tool Expert? Answer questions, earn points and help others
