Question about Magellan RoadMate 2200T GPS Receiver
Unit turns off even when on car charger it has low battery
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Posted on Oct 02, 2010
My Garmin Nuvi 265W Won't turn on
Lets put the battery issue aside for the moment. A Nuvi should power up as soon as the charger is plugged into it. It will turn on even if the battery has been removed. Of course, once you remove the charger, the unit will die immediately because the battery has been removed.
The first thing I would suggest doing is trying a reset. There are 2 ways to reset a Nuvi 2xx or 2xxW.
On some units (earlier versions), there is a flap on the bottom of the unit that you press in momentarily to reset the unit. There will be a label on the bottom with the units serial number and the word "reset" on the label.
The other method (newer versions) is to slide the on/off power switch to the left and hold it for at least 10 seconds.
Another common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
More information can be found here:
http://www.sharc.net/discus/messages/6/313.html?1338221806
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 26, 2013 | Garmin nuvi 265 Car GPS Receiver
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
Unit will not power on.
its probably not the battery, your gps should run even without a battery if the power port/circuit is ok. unfortunately this is a common problem that the usb port gets damaged with this and many other model of magellans gps systems.
if you had it plugged in to the car charger, make sure the green light is on while charging, if its not, you might have a blown fuse in the charger or the fuse for the cigarette adapter in the car.
if the green light is on, try letting it on for a few hours, then try and turn it on. if and when it turns on, you can verify if its charging by going to the system settings then the power option. the battery bar should turn green and move from right to left if its charging. if the battery is slightly low but the bar is not moving left to right, then its not charging.
you can check the charging by using the usb cable provided with your unit and hook it up to your computer to verify if its charging. but i suspect it has a bad power port (usb connector)
i hate to be the barer of bad news, because rarely do i get a good rating for being the barer of bad news, but hopefully you just have a bad charger or a blown fuse in your adapter or car.
good luck
bill
Oct 19, 2009 | GPS
Forerunner 305 keeps beeping, turning on and off every 5 seconds
I think I had the same problem. You do not write if your device were connected to the PC. My device was, and I finally got the suspicision, that it died because the battery was so low, that it crashed when the PC polled it as an usb unit.
So, I connected the unit directly to the charger unit that came with the unit, and now it works. So, try to connect directly to your charger, when your battery is totally drained.
Sep 16, 2009 | Garmin Forerunner 305 GPS Receiver
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Magellan RoadMate 2200T GPS Receiver Logo
55 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
