Question about Aiptek HyperPen 12000U (HYPERPEN12000U) Graphic Tablet
Doesn't respond to the pen well
I have to either angle my hand so that the pen nib meets the tablet at a right angle or press harder but I don;t want to damage it. I thought orientating it might solve the problem but I can't even find the option to do it. Sometimes when I'm trying to draw it goes a bit crazy and draws a straight line to somewhere else on the screen. I've not bashed it or anything so I don't know what's happened?
  • kalahariuk Oct 02, 2008
    I have never had a table before, I was stoked when mine arrived an hour ago.
    but everytime I touch the nib to the tablet, the nib disappears up into the pen, leaving a millimetre showing, so I have to hold it straight upright.
    and yes it skips and dances and plays all sorts of sillibuggaz
Having the mouse on the pad at the same time may be an issue but it could be the Operating system. When I first got mine the same thing happened to me because i was using the driver that came in the CD on windows Vista. The problem was solved when I installed and updated driver for Windows XP and Vista from the official site http://www.aiptek.com/drivers just look for the model and download the driver.
Posted on Sep 09, 2009
I had the same problem, and my fix was really simple. Did you make sure that your mouse and pen aren't on the tablet at the same time? I took my mouse off the tablet, the pen immediately stopped jumping around.
Posted on Mar 12, 2009
I still have the problem, even though I don't have the mouse on my tablet as well as I have installed the latest driver.
So, my operating system is Windows Vista 32bit.
The pen still jumps around.
What's the problem here?
Posted on Mar 26, 2010
The pen on my Samsung Galaxy tab 3 only works sporadically. ..... it'll start recognising threw pen when it's about 2 inches away from the tablet...... there are some spots. .....s note mainly. ..... that...
you mean galaxy note 3 .first be sure the pen has a nib in it not a hole where one has fallen out. then it is about 1/16th or so outof the pen and rounded next try replacing the pen nib your phone came with a packet of replacements. they pull out and are snapped back in. Last and for sure , there is actually a battery inside the pen if it is old and weak you will have to get another pen say from ebay (best price) but before you do go to phone store and use one of theirs to test . if you have the same problem and only certain spots do not work on the screen then your digitizer screen is in need of replacement. also another ebay cheapest item. but whatever it turns out to be it is fixable. come back if you need advice will check every couple weeks.
So pen has nib , or nib needs replacement,pen has weak battery and need replacement or digitizer needs replacement. all solutions are under 100 dollars most under 50 . no nibs or bad nibs under 15.
Dec 23, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My pen writes even if it's hovering over the board. =[
I had this same problem. I found my solution on here, but i don't know if it will work for you. Take the pen and hit the head of the pen into your hand 5 times (pretty hard i hurt my hand while doing it but not too hard) and then do the same with the eraser. It worked fine for me afterwords. Something about humid weather and the sticking of the pressure thing in the pen. I hope this helps
Apr 01, 2010 | Wacom Intuos3 Graphic Tablet
How to change pen nib for graphire4 cte-440
just pull the pen nibs right out with a pair of tweezers or pliers… Its just a piece of plastic - look at it. You might even find a substitute in your own home
Mar 31, 2009 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
My Wacom Bamboo Tablet Pen: only the pen was dropped. Now the eraser works but the pen tip does not. Neither do the buttons. The tablet itself does not pick up the pen tip's presence, but it works perfect...
Try replacing the pen nib. Take out the little nib with a tweezer or something along those lines and replace it with a new one. There should be a few of them when you bought the tablet. Also, try looking at the tablet properties.
Feb 02, 2009 | Toshiba Portege M200 Tablet PC
When hovering the pen, it acts as if I am pressing
Sounds like you're either holding the stylis to close to the nib and bumping the nib, or, there is dirt in behind the nib causing it to not be fully released when you lift it.
The nib does not need to make contact with the artboard, just be depressed when in range of it.
The nibs can be pulled out and replaced - cheap as to buy new nibs. I've never pulled one out and refitted the same used nib, with a 'good' pair of tweezers you can try, but you risk squeezing the nib out of shape - worth a go?
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 31, 2009 | Wacom Bamboo Fun Medium (CTE650S)
The 5 extra nibs for pen missing or where are they?
the extra nibs comes in the same plastic package as the pen, there's very small tapped beside the pen
Jan 10, 2009 | Wacom Intuos3 Graphic Tablet
Classic Pen Woes
Hi , Mnemosyne , i'm the Guest who had the exact same of your problem , i contacted WACOM and there solution was as follow : " This problem is, although uncommon, usually easily fixable. The first and fastest solution is to simply press the eraser a few times to release it from binding on the side of the pen. If that does not work, pull the white plastic nib, and take a fingernail file (LIGHTLY) to the back end of the nib, making sure to remove any burs or flaring from the nib. I have seen this problem myself, albeit uncommon " , they also suggested if all fails then change the nib ( and thats exactly what i did , i changed the plastic nib with the felt nib - i like it better anyways thats why i didn't bother filing the plastic nib - and WALA my problem was solved and the pen is working like a charm , hope this helps .
SLH
Jun 21, 2008 | Wacom Intuos3 6x11
Unresponsive pen
Defective pen. Replace the nib. If that doesn't work, replace the pen.
Jan 26, 2008 | Wacom (EP130EPE) Digital Pen
Gateway tablet screen does not respond to pen.
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
Sep 30, 2007 | Gateway M275 Tablet PC
Aiptek HyperPen 12000U (HYPERPEN12000U) Graphic Tablet Logo
531 people viewed this question
Top Aiptek Computers & Internet Experts
David
David
Willem.
Willem.
Gareth Cockram
Gareth Cockram
Are you an Aiptek Computer and Internet Expert? Answer questions, earn points and help others
