Question about Nikon Speedlight SB-600 TTL Flash
Minor battery corrosion caused flash to stop working because it will not power up.
  • 10,319 Answers
Use Naptha or a solvent such as lighter fluid to remove the corrosion. Apply this liquid on a Q Tip to apply. You may have to leave the qtip on the terminal for a few minutes to let it soak in good to loosen up. After the corrosion is gone the terminals will look like untreated steel so wipe clean with alcohol with a Q Tip too.If the flash still does not work the corrosion has worked its way into the wiring leading to these terminals. Replace the wires if possible if the solvent can not penatrate enough to operate the flash
Posted on Oct 01, 2010
Has power, lights flash, but the wheels stopped working. The small black relay switch? buzz's and battery is charged.
what is make model and year of vehicle please. what is the engine option? please add detail and repost the query
Jul 03, 2015 | Cars & Trucks
Starter circuit on pickup stops working at random
you have a loose connection. it is either on your battery, or right on the starter where the power wire connects. ford's are notorious for the starter wiring getting some corrosion. once you find out if the battery cables are loose, remove them, then crawl underneath and remove the wires to the starter and inspect them for corrosion. a wire brush will be sufficient to scuff the surface up a bit, then make sure everything is nice and tight. this should solve the issue.
9 times out of 10 its a loose ground wire on the battery or battery terminal corrosion.
Oct 12, 2014 | MTX ThunderForms 2001-2003 Ford F-150...
Will not start
Try cleaning the battery terminals - it is the most common cause even minor corrosion can cause low cold cranking amperage from the battery. It is also possible if there is corrosion that the battery is low on charge. If the battery terminals are clean and the battery is all good then it is probably the solenoid on the starter motor.
Feb 05, 2013 | 2008 Jeep Commander
Five minutes ago our 1988 Dodge Grand Caravan was running. I replaced a brake light bulb and started it to test. Now it is dead. Completely. No current getting from the battery to any electrical...
Take a volt meter and read the battery terminals to insure there is power. You should have 12 volts dc or a little over. This may be caused by a direct short in the battery cables. Also tight aint always right. It doesn't matter how tight you have a connection if there is something (ie corrosion) interfering with the connection. To check this clean the terminals with a battery brush or a rough brush or file, then reconnect the terminals.
P.S. Coca Cola will also eat the corrosion off of anything.
Apr 17, 2011 | 2000 Dodge Caravan
My Pentax F 801 has suffered minor damage from battery corrosion and the bottom of the battery holding frame has cracked. New batteries and the camera still works fine but I would like to get a new...
Your old battey pack can be cleaned with lighter fluid such as Rosonol. Use a Q Tip that is saturated and apply as much as you want. Let dry overnight and brush away the corrosion in the morning
Jan 13, 2010 | Photography
I have three, all stored for years, and now they all do not work. Is there some internal battery that needs replacement ( beyond the regular batteries) or something that I can do to revive them? Thanks!
Flashes stored a long time often suffer from capacitor failure. The first thing to try however is leave the batteries in for a few minutes powered on to see if they will charge. If this doesn't work, then they'll need professional repair.
Jan 01, 2010 | Vivitar 283 Flash
A leaking coppertop battery has resulted in corrosion of spring terminal second from base. attemped cleaning of spring and New batteries will not power up the flash unit
If the corrosion worked its way in to the circuit board, you have 2 choices.
Get it repaired at Canon or somewhere else.
Buy a replacement.
Oct 20, 2009 | Canon Speedlite 550EX TTL Flash
My Clarke 24v cordless impact driver just stopped dead! batteries are fine and charged. Any oppinions?
Have you tried to wipe the contacts on the battery and the Clarke 24 V driver with some 220 sandpaper. There could be some minor corrosion on the contacts sometimes not visible and check
that connectors are actually making contact. If this does not work check your on off switch. This
could be shot.
Sep 07, 2009 | Drills
Lg vx9400 screen flashes on and off when attempting to charge
It's trying to stay charging the battery because it can move the power to the actual plastic causing it todo a minor flash, it's no biggy. :l
Aug 24, 2009 | LG VX9400 Cellular Phone
Canon Powershot A550 flash will not work it just blinks on & off?
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Dec 01, 2008 | Canon PowerShot A550 Digital Camera
Nikon Speedlight SB-600 TTL Flash Logo
175 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
