Question about Mitsubishi WS-55819 55" Rear Projection Television
I turn the set on but i don't get a picture. I can hear the sound fine but evrything is black. when i hit the menu or input button the words come up in yellow but the screen also looks a dark gray. there is a white look at the bottom of the screen but no picture. Somebody suggested replacing the lamp but i don't see a lamp only three separate lamps. Can U Help? Mitsubishi 55819
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
It has no lamp, just the three picture tubes and they are not your problem.
I would suggest you do an inspection looking for any signs of Glycol leaks.
Each of the three tubes has a sealed area with this liquid in it, clear and very toxic.
Pull the front speaker grill off and remove the inspection plate behind it. There are three large circuit boards. Right to left as seen from the front---signal/control board green in color, Middle board tan colored----deflection/power and far left board main power and HV supply.
Leaks may be hard to see, it will not be a lot of liquid and or may appear as discoloration of parts. Leaks if there will be in first 3 inches or so of front of boards.
The green board is the most likely in your case---I will attach a photo of what it looks like and you will see the liquid on the square part on that board. The board has parts soldered to the TOP! and slight amounts may appear as discoloration of solder seen there.
As I said, you must look closely as even a tiny amount can cause real odd problems.
Let me know what you find and I will assist you.
If this helped, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Oct 01, 2010
Testimonial: "Excellent..This is the type of answer I'm looking for."
  • jacksoncc Oct 08, 2010
    No I don't believe a fluid leak is the problem and I'm reluctant to believe it's the pico fuses and convergence ICs since i don't have the 2-2 trouble code
How do I get my t.v. fixed it has no picture
First thing to do is to grab your remote and look for the INPUT or the SOURCE button. While you can hear the program hit one of those two buttons and toggle through the inputs. I am betting that you will come across the video side of it.
Feb 27, 2015 | Seiki SE50FY10 50 Inch 1080p Black
My tv turns on an off, and the picture and sound works fine. The problem I am having, is that no matter what button you push on the remote, or the tv itself, it just brings up the input. You could hit...
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual functions controls board that have like buttons POWER,Channels + -,Volume + -,MENU.This manual functions controls board it is shorted.
May 21, 2011 | Element Electronics ELCHW261 26 in. TV
I am currently house-sitting for a family friend. Watching TV last night, the family pet jumped on me, causing me to hit the knobby button between the menu and reset buttons on a sony universal remote,...
This universal remote (or the TV's original remote) should have an Input button, which allows you to switch the various inputs available on the TV (such as HDMI, composite, over-the-air, cable, etc). You can try hitting Input until you see a picture, but be sure to turn on any devices connected such as set top boxes, DVD players, etc.
Mar 04, 2011 | Sony Televison & Video
My television screen went black, but there is has sound
Make sure your tv is on the right input first of all. The newer flat panel lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
Aug 15, 2009 | Televison & Video
My ps3 will turn and u can hear the sound but no picture?
Hold Down The Power Button For 20 Seconds
You Will Hear A Few Beeps But Don't Let Go Until You See A Picture
Cheers, Tristan
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
May 30, 2008 | Toshiba REGZA 47HL167 TV
No sound or picture
Try 2 things:
1. If you have a cable box with the yellow/white/red outputs, use a compatible cord to run the 3 to another input on your TV (ie input 1 vs cable). and/or
2. Do a Factory reset. Hold the "menu" button on your TV then on your remote hit "menu" then "8" then "select" and go to "factory reset". You may have to unplug the TV as it may freeze on "factory reset". Replug it then try it out.
Hope it works.
Apr 03, 2008 | Hitachi 51F510 51" Rear Projection...
Tv picture is black, sound is fine
Sorry, no easy answer here. On an older set this would be espected and not worth repairing, but you should take this to a TV shop for troubleshooting. Most likely culprit is the flyback transformer and/or the horizontal deflection.
Hope Ya Fix It.
Jan 31, 2008 | JVC AV-27F702 27" TV
HAVE PICTURE BUT NO SOUND
check for center channel option in menu, change option and test
May 21, 2007 | JVC AV-56WP30 56" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
