Question about GE Kitchen Ranges
I was cleaning stove top and all of a sudden the electrode on thr front right burner started clicking and the middle burner in the rear clicking also and will not stop.
  • L100301 Jun 01, 2008
    The help that Benimur gave me was excellent and he was very kind and understanding with me. I'm sure he hasn't had a client like me.I can only type a sentence (short time)about 5 minutes and I'm about one step from alhiemer which means that took about another 5 to 10 minutes . So was I happy to get a man that took his time with me (seldom ever happen in my lifetime).I give him 100%. Thank you Mr Benimur. P.S. Cooking worked.I did write this before but I don't mind doing it again.
IWAS TOLD TO DRY IT OUT WITH MY VACUUM BLOWER WHICH DID NOT WORK THEN HE GAVE ME PLAN B.WHICH WAS TO COOK BREAKFAST EVEN THOUGH IT WAS STILL CLICKING AND THE HEAT FROM THE STOVE WOULD PROBABLY DRY IT OUT......IT DID AND IT STOP CLICKING!
Posted on May 28, 2008
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
I am disassembling a Kenmore stove top gas burner to clean under the stove top. To do so you actually need to unscrew the burners, which I've done, but then I need to unhook the spark electrode, which...
The electrode is held onto the burner head with a screw through the mounting tab. They can get crusted over and it's not always easy to see the screw head, but it's there.
Jul 04, 2011 | Microwave Ovens
Amana stove top burners click, and gas comes out, but won't ignite. It's a self cleaning ARG7200, about 11 or 12 years old. Oh, and can I lift this top? I'm used to doing that with old pilot-light...
A weak erratic spark from one or more electrode usually indicates a bad spark module. No spark from one of the electrodes while the others work properly usually indicates a bad electrode. Inspect the porcelain of the electrode for cracks, chips or burn marks. If there are any, the electrode should be replaced. If one of the burner knobs is turned to the light position and nothing happens, but all the others function correctly, the spark ignition switch for that one burner is likely bad. The switch can be taken out of the system and checked with an ohmmeter. It should close for continuity at the light position only.
Go here for:
Amana Range/Stove/Oven Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Amana Kitchen Ranges
Electric start gas range
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Nov 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Burner not working
Sometimes there is "leak" on the cable - the insulation breaks down some place else some the clicking sound is heard but no lighting. Look to see if the arching is at the electrode beside the burner - if it is then try cleaning the electrode and the areas around the burner so as to give better conduction to thr frame o the stove
Regards
Nov 16, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Apr 06, 2007 | Dacor Preference SGM466 Gas Cooktop
General Electric stove top burner does not light
whalerpaul, To get access to the gas burner valves you have to: 1.UNPLUG THE POWER CORD 2. Remove all burners 3. There are 2 screws under each burner, remove all of them and lift up the top panel 4. Remove all knobs, remove screws holding the manifold panel (two on top and four on the bottom) 5. Carefully pull out the manifold panel and remove two wires from the oven light switch, put the manifold panel on side Part number for the right front gas burner valve is WB21K12 and you can buy it here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542247749&type=10&subid=
Jan 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
194 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
