Question about Microwave Ovens
We installed a GE JVM1750 and rotated the fan to recirculate the air. Air blows out the vent in the front, but does not pull air in from the bottom.... any ideas?
  • Microwave Ovens Master
  • 9,047 Answers
I would first suggest that you consult the owner's manual and installation guide.
If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You may have a clogged charcoal filter so that should be checked. They need to be replaced about every six months or so.
You can find helpful exploded view diagrams and order parts and filters by entering your full model number here.
Posted on Oct 02, 2010
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
I have a GE Spacemaker Microwave DE68-40861A that has a built in range vent. The fan motor blows just fine, but there is no airflow. Apparently this was installed improperly. What would be blocking the...
take microwave down. There is 1 screw on the back that hold fan in. Pull screw out and the fan will lift out. Roll fan so that opening of fins faces to the front. set it back in put screw back in and remount microwave.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Can i vent my jvm-1440 microwave/fan ?
yes, you can recirculate it out the front which i suppose u do currrently... you may also vent it out the top, or the rear. to do this u must drop the unit down,and rotate the fan motor to point the appropriate direction, and also install or have a exterior venting piping existing currently..
Apr 16, 2010 | GE JVM1440 Microwave Oven
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Recirculation fan does not pull in air/steam/smoke
The issue is that the fan on that unit is a reconfigurable fan. If there is a vent, you install the fan one way, if there is no vent pipe to the outside, you install the fan another way. https://www.manualslib.com/manual/294916/Maytag-Mmv4205.html?page=9#manual
Sep 04, 2017 | Maytag MMV5165 Microwave Oven
GE JVM1640 micro wave oven
You can check and / or correct your installation with help from the installation instructions.
You can download GE owner's manuals and installation instructions here.
Feb 04, 2009 | GE JVM1640 Microwave Oven
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
