Question about Canon ZR85 Mini DV Digital Camcorder
Rthe tape wont load and it dings - Canon ZR85 Mini DV Digital Camcorder
    Genius:
  • 1,812 Answers
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Oct 03, 2010
Headlight wont work, doors constantly lock and unlock, door alarm dings off and on, plus other issues.
Check on driver side door is wired pass be twin door and car passe wire check the wire ground check for cut off 1 those wire is touching ground check one by one end use electric tape good look
Sep 12, 2017 | Cars & Trucks
Changed battery terminals and now dinging wont stop unless warning light fuse removed
It sounds like it thinks the key is still in it all the time. Try turning the key forward to the on position, but not running, so the dinging stops. disconnect the battery. Remove the key completely and reconnect the battery.
Oct 21, 2014 | 2005 Dodge Caravan
There is a dinging noise when i open my door after removing the key
The key chime in ignition cylinder is shorting out against the steering column. Turn key on, take a very thin long pin and at the underside of the steering column cover there's a small hole, push pin until you feel a metal tab pushing up,pull out the cylinder. You will see a little metal tab pushed up against the ignition cylinder wall.the plastic piece that keeps it in place is probably broken. You can put a piece of electrical tape on it and be done with it, but chime won't work at all, the down side of this....the only eay to replace that key chime id to buy the clockspring, around $250 plus labor, steering wheel has to be removed. ..
Feb 10, 2014 | 1997 Mercury Mountaineer
Won't spin
Ok the must be empty to spin. Make sure the water has all gone. Any way clean out the pump trap behind the little door at the bottom front. I assume it is a fron load . you haveny\t said what type of machine have you? Thats like saying my car wont start but what type of car is it? Once the water hs gone try spin ing the machine dry on a spin only cycle. If it wont spin then the motor brushes should be checked. You might have to remove rthe motor fort this Call for assistanve when you get this far.Good luck
Sep 05, 2010 | Washing Machines
My radio wont shut off and the door keeps dinging after key is removed
This is usually a case of a broken wire in the driver's side door sill, on the New Body Style 2004 ( not a lightning or Heritage ).
Pop the door sill cover up, and you are looking for a purple or blue w/ white stripe wire where 3 wires are spliced. The splice tape looks like hockey tape, so water can still get in.
Here are 2 pictures of the broken wire locations
Jul 15, 2010 | 2004 Ford F150
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Washer wont turn on flashing de
Open the washer and clean the drain pump.
May 19, 2009 | LG WM1814CW Front Load Washer
Will not start only ding ding sound
DING DING SOUND USALLY MEANS END OF CYCLE. MAY NEED TO ORDER MMC AN CHANGE THAT
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
35 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
