Question about Garden
Repair / shop manual for husqvarna 235e chainsaw
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: Chainsaw Service manual for Husqvarna in New Zealand
I USED GOOGLE SEARCH THEN JUST DOWNLOADED IT. I GOT THE ONE FOR MODEL 50, 50 SPECIAL AND 51. GOOD LUCK!!!
Posted on Jan 25, 2009
dontbother10
  • 2220 Answers
SOURCE: how do i release the brake spring on a husqvarna
Immobilize the clutch cover (blocks of wood on a flat surface to protect the finish) in a vise or to a work surface,
Use pliers or a crescent wrench and rotate it clockwise until it latches open. This will require some force.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 01, 2010
  • 78 Answers
SOURCE: Looking for a repair manual for husqvarna 136
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Posted on Nov 15, 2010
puertobori
  • 7733 Answers
SOURCE: how do you replace a chain on a Husqvarna 235e
Take out the chain guard.Once there you will look at a bolt holding the chain plate.Untight the bolt and adjust the cahin,but not too tight just test by hand if it moves freely but tight.Usually a gap of about 1/4 or less is enough,tight and guard back.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 20, 2010
I need to know the correct fuel ratio for a Huska Vona 235 chainsaw
50:1. Your manual is here.
[PDF]OM, 235 e/ 240 e, 2008-02, Chain Saw - Husqvarna www.husqvarna.com/.../HUSO%2FHUSO2008_USen%2FHUSO2008_USen_O08020...
  1. Cached
235e 240e. Operator's manual .... You will find the following labels on your chain saw: ..... recommended (a lean mixture may mean that the fuel lasts longer than ...
http://www.husqvarna.com%2Fddocdownload%2FHUSO%252FHUSO2008_USen%252FHUSO2008_USen_O0802031_.pdf&usg=AFQjCNHmUdP3dUYTbfqmTs7Z7SATwGd1Nw
Jan 23, 2017 | Garden
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
How to get chain guard off 235e husqvarna?
The chainbrake must be open, then turn the chain tightening handle counter clockwise. The side cover can then be removed.
Apr 26, 2014 | Husqvarna Forest & Garden #952802239 235E...
How to adjust oil flow on husqvarna 235e
I dont think you can on this model. I think its permenantly set. However, depending on the season you can get 'thicker'/'thiner' chain oils.
Sep 06, 2012 | Husqvarna 14-Inch 34cc Gas Powered...
How heavy duty is the Husqvarna 235E 14" Gas Chainsaw? can it take a larger bar?
The 235e chainsaw was a complete disaster, all sorts of problems too many to list, i would not put a longer bar on it.
Feb 27, 2011 | Husqvarna Garden
How do you replace a chain on a Husqvarna 235e
Nov 20, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain oiler not working on my 235e saw
Manual de-mystification
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Nov 13, 2009 | Husqvarna Forest & Garden #952802239 235E...
Garden Logo
1,132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
