Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Hi, There is a high pitched whirring sound coming from lower part of the vacuum. When I tilt it toward me (while standing in the normal vacuuming stance) the sound sometimes lessens for a minute or so. I have tried the following things: -cleaned the two sponge filters -emptied the dirt receptacle -removed the roller and cleaned it -cleaned the brushes -the belt is not ragged and does not seem floppy -checked all of the airways for clogs (including removing the wheel base) Can you help? Thanks so much!
    President:
  • 1,509 Answers
Your looking for some dirt stuck in some thing you didn't check yet. with the roller out and the belt out of the way run it to see if it still makes the noise. if it does then you looking at the impeller or the motor bearing themselfs those bearings can be full of dirt or worn out If its running smooth with the belt off then the rooler bearings are next they may only squeel with the belt load on them but install it with the belt off and see if it turns smoothly, ( it should twirl with your finger ) if it turns hard keep cleaning and or replace the bearings, Then run it again to make sure it's not making the noise hten take it apart again and put the belt on and see if its fixed, It's possible to put the belt on backwards the brush should be turning as to pull the machine forward on the floor.
Posted on Oct 01, 2010
My vacuum is making a loud whirring sound and is hotter than normal.
Hi Kelsey! I understand how frustrating this must be. Dirty filters or a clog can cause the vacuum to change sound and be hotter than normal.
Here is a quick link to troubleshooting the excessive noise:
http://www.bissell.com/FAQDetail.aspx?id=1362&cid=ccsocial
Mar 28, 2013 | Bissell Cleanview Helix Bagless Upright...
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
Its stopped suction but the belt is fine
I'm sorry to hear you're having difficulty with your DC33. The issue you've described with the brushbar sounds unusual, and we'd appreciate the opportunity to provide further assistance. If you give our free Helpline a call, we'll be able to determine what's causing the noise, and may be able to resolve this right over the phone.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it'll help if you have the machine to hand when you call, so we can run through some troubleshooting with you.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 18, 2012 | Dyson DC33 Bagged Upright Vacuum
Hi, i just bought a Dyson DC 22 yesterday and it makes this really annoying high pitched noise? Is thia normal? Or should i take it back to the supplier?
Sorry to hear you're having difficulties your DC22. So we can identify the cause of the high-pitched noise you're hearing, and recommend the best course of action, I'd suggest calling us directly so one of our experts can diagnose any issues over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 01, 2011 | Dyson DC22 Motorhead Canister Vacuum...
It makes a squeaking/scraping sound when you stand it upright while machine is turned on. Only way we can use it is to keep the machine tilted back. The release lever is broken in that the vacuum tilts...
Check belt and roller or take it for vacum tuneup. Tune ups are real cheap, like $20 and they will adjust, replace belt and clean. Well worth it as it is a great quality vac
Feb 10, 2011 | Riccar R100 Vacuum
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
NO SUCTION HIGH PITCHED MOTOR
sounds like the bearings or brushes in the motor are bad.
Oct 23, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
High pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
May 23, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
105 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
