Question about Dishwashers
I have a bissell pro heat turbo and there is no water coming out I done a cleaning on it and I check other to see if any were clog up wyhat is my problem
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Oct 01, 2010
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
Bissell instruction manuals
Most likely Water Tank Filter clog. The filter is located in the cap of the water tank (looks like a screen) remove it and clean and replace it. You may want to check the User's Guide for anyother filters that should be cleaned after each use.
Jul 28, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Soap mixing with water on bissell pro heat 2
Filter clog problem. Check your User's Guide for filter cleaning.
Jul 04, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
The handle hose on my bissel proheat turbo 2x is clogged, how do I unclog it?
Try suctioning clean water from a sink or bucket with the attachment removed from the hose. If the attachment is clogged, soak in hot tap water for 30 minutes and clean the end with an old toothbrush.
Here's a link to locate a BISSELL Authorized Service Center if you continue to have problems.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 10, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel pro heat wont dispense any water
these pumps always fail. try to replace the pump. also check for clogs in the spray nozzles and tubes
Feb 26, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
ut
Sep 04, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Taking the brush off the pro heat bissel?
try changing the belts first if you buy the original belt package it comes with instructions on how to replace them, if not it probably has a clogged heater core
Oct 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
