Question about Danby DDR586R Dehumidifier
The compressor goes on but it never fills up with water
  • Danby Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Oct 01, 2010
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Compressor not running, possibly because refrigerant is low
Jul 30, 2016 | Danby Dehumidifiers
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
Not creating water. Unit runs but the cistern does not fill up like normal
Many times on a dehumidifier we hear the fan run...and think all is ok. But the key is if the compressor is running. Listen for the "refrigerator" type sound ....It must first be determined if the compressor is running...and if so is the filter and the coil behind the filter clean
May 11, 2010 | Danby DDR601 Dehumidifier
I have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and...
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 19, 2009 | Ebac HD880 Dehumidifier
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
My kenmore 50 pint dehumidifier 54501 runs but it does not taking in water
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
Jul 18, 2009 | Kenmore 54501 Dehumidifier
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Jun 17, 2009 | LG LHD45EL Dehumidifier
Oil inside the water collection res
the compressor runs in oil. suspect you have a quite bad leak and loss all the gas - hence no water collection and the compressor oil is being pumped out thro the leak
Jun 26, 2008 | Whirlpool AD25BBK Dehumidifier
No water in bucket
if you can verify that the compressor motor is actually turning, then the problem is either a freon leak or a worn out compressor. if it is not turning, then the problem is either a damaged motor or motor is not getting voltage--need testing with meter to determine why. cheaper in long run to buy a new unit if bad compressor or motor or freon fill, but a fill may be only temporary if leak persists.
Aug 17, 2007 | Soleus CFM-25 Dehumidifier
Danby DDR586R Dehumidifier Logo
279 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
