How to send a message with command prompt - Computers & Internet
    Sergeant:
  • 231 Answers
Here is a direct link to answer good luck
http://answers.yahoo.com/question/index?qid=20080217131820AAQ6FrA
Posted on Oct 01, 2010
Windows not genuine notification
Windows 7 not genuine notification using command propt How to make Windows 7 genuine using Command Prompt
Press Windows key + R
Now "run" box will appear , in "run" box type CMD
Click on OK
Note : Run CMD as Administrator
Now command prompt will appear
In command prompt type SLMGR -REARM
Hit Enter.
Wait 5-10 seconds
Now a message will appear as shown in image below.
Done !!!
Now your Windows 7 is genuine .. :D
Restart your PC once. Hereafter you won't see the warning message that "Windows 7 is not genuine"
Apr 05, 2014 | Microsoft Windows 7 Ultimate 32 bit Full...
System disc
What type of system disc ?
operating system disc
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'.
Reboot the computer.
Hope this helps.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
Mar 06, 2014 | HP Compaq Presario SR1750NX PC Desktop
After format completes cp gets restart and occur file:\boot\bcd status:0xc000000e
All credit to J W Stuart
"How to repair and reboot to Windows 7:
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the display.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
Note: Please perform step j as detailed, startup repair must be run multiple times.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'. This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer."
Nov 22, 2012 | Dell Inspiron 15r n5110 Laptop
I need to find a set up disc
What operating system set up disc are you referring to ?
bootrec.exe /fixmbr
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
System disks startup
bootrec.exe /fixmbr
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
How to Create a Windows 7 System Repair Disc:
or
bootrec.exe /fixmbr
hope this helps
Aug 09, 2012 | Computers & Internet
Cannot play games (example big fish games) after being downloaded to my pc. I get this message d3derr_notavailable
Your graphics card most likely doesn't support Direct 3D. You can test using the following command in a cmd prompt window dxdiag
In XP click start/run and type cmd in the run box to open a command prompt window.
In Vista/Win7 to open the command prompt, either go through the start menu - click start, All Programs, Accessories, then click on Command Prompt or in the run box type: cmd .
Dec 19, 2010 | Computers & Internet
I am trying to update my back up but I get a message the disc is full (although it does not appear to be when I look at its porperties). I am instructed to delete and backup the files again and when I try...
I thing your file system is FAT32.fat 32 can only store file size of maximum of 4GB.change file system to NTFS.
To convert a volume to NTFS from the command prompt
  1. Open Command Prompt. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. In the command prompt window, type: convert drive_letter: /fs:ntfs
For example, typing convert X: /fs:ntfs would format drive X: with the ntfs format.
Aug 29, 2010 | LaCie (300770) 250 GB Hard Drive
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Feb 02, 2010 | Zebra LP 2844 Thermal Printer
I cant send any messages keeps saying hook uo to
Switch off your broadband connection for ten seconds and try to switch it back on. Go to control panel and click Internet connection as soon as wizard displays. Examine if the settings is enabled. Close the control panel and open run command and type cmd. After typing, when it prompts a command, type ipconfig and see if IP address and provider is listed with gateway and subnet. If it has all the addresses, so you can connect back to GMAIL. Thanks.
Jun 20, 2009 | Google Gmail
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
