Question about Frigidaire Electric Dryer
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
  • Frigidaire Master
  • 3,740 Answers
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Posted on Oct 01, 2010
Testimonial: "It was a good suggestion. I checked the line but was ok I called a service tech. and found out the control board went out. But the first thing he c "
  • Kelly
    Kelly Oct 03, 2010
    Hi again, I mentioned after trying the CB rest to let me know what you have found out. The process would have been read for shorts to ground from the power plug to the chassis then the next step would have regretably been to change the control board. Hopefully the tech did a circuit check and at least gave you a 90 day warranty on the part. Here is the truth. If there is a circuit problem in the unit it can very soon damage your new control board. Make sure you keep your paperwork from the repair. You just may need it if the tech did not troubleshoot the wiring / circuits in the dryer.
    Glad to hear your up and running again (fingers crossed for a no repeat)
    Kelly
  • Frigidaire Master
  • 3,051 Answers
Hello there:
This is due to a loss of power to the dryer
PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Dryer will not start. Display shows PF
could pf mean particle filter and it needs cleaning
Jun 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
Fridgidaire dryer stops with code PF
pf isd power failure
with so many differant possiblities
it would be hard to nail it down here
but i would check my outlet chord and termianl post
where the chord connects to the dryer
one or more of the connections could be loose
Jul 01, 2009 | Frigidaire Electric Dryer
Code
The PF stand for Power Failure. When you unplugged it, it truely did have a power failure..
Nov 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
865 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
