Question about Sunbeam 1.7 Liter Hot Water Kettle Electric Kettle
How do i take the handle off of my sunbeam kettle 3233-33? The switch is not connecting properly - can't turn it on. I've taken the screws out...
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: HD 4651/C Electric Kettle Handle switch lights but wont heat
This maybe the thermo fuse, and or the heating element that is defective. These parts must be properly replaced for safety issues.
Usually these appliances are not worth to service.
Jerry G.
Posted on Apr 29, 2008
mc1bean
  • 3053 Answers
SOURCE: Sunbeam electric kettle: model 5739-33
In this case i think the element went out. Common with those. Yes i believe in this case it is not worth the cost and trouble to even attempt to fix it. Here is the cheapest place I found from a trusted store to get another one, and of course can have it shipped if you want. Target on line, For your convenience i put this link below and they have some that are a close out, that you cab get for $17.99 I hope this helps you , to bring the Joy Back :) Just copy and paste that link in your browser, should take you to the right section. Thanks Mike from fixya
http://www.target.com/s/180-4435579-9261449?keywords=sunbeam%20electric%20kettles&CPNG=rtcs%20coffee,%20tea%20&%20beverages&adgroup=rtcs%20%20electric%20kettles%20sunbeam&LNM=Sunbeam%20electric%20kettles&MT=broad&AFID=google&LID=26p2274095&KID=161e9907-52ea-f229-e371-00007fe2bb43&ref=tgt_adv_XS000000
Posted on Jul 09, 2011
Where can i purchase a replacement heating element for my Sunbeam classic electric kettle
Do a google search on the web for Sunbeam support. Get in touch with them to find out where they have a dealer that can sell parts for their products.
You will need the proper crimp tools and connectors to connect the new element.
Take note that some of these appliances were designed to not be serviceable. When you call Sunbeam, they will be able to tell you that, and if they can see replacement parts for your kettle.
Many times when I had a bad heating element in a kettle, I found the therm fuse also had to be changed.
Jerry G.
Jun 04, 2012 | Sunbeam Kitchen Appliances - Others
Sunbeam electric kettle: model 5739-33 is just out of warranty.Went to use this kettle this morning, no blue 'on' light and no joy.Opened to cover to be sure all wires are connected, everything looks okay....
Jul 09, 2011 | Sunbeam Kitchen Appliances - Others
My Braun electric kettle won't click on. Do I need to replace the kettle or is there some way it can be fixed?
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Jan 16, 2011 | Braun WK200 Cordless Electric Kettle
Retro Popcorn Maker crank handle connection to kettle
The crank handle screws in counter-clockwise so it doesn't unscrew when you dump the kettle. Try that.
Jan 16, 2010 | Helman Group RKP-630 Popcorn Maker
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Oct 11, 2009 | Morphy Richards 43025 Electric Kettle
Jerry G.
Apr 07, 2008 | Kitchen Appliances - Others
Broken switch
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod.
Dec 28, 2007 | Braun WK200 Cordless Electric Kettle
Switch problem
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod..
Apr 16, 2007 | Braun WK200 Cordless Electric Kettle
Sunbeam 1.7 Liter Hot Water Kettle Electric Kettle Logo
80 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
