Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
What is the max cpu i can put in - E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
  • E-Machines Master
  • 11,800 Answers
Pentium 4 3.06 - the version with 533MHz bus speed
Posted on Oct 02, 2010
If i update my cpu to t7800 will it give me more max ram its got the t7100 in it at the moment with 2 slots. 2x2gb ram max 4gb or do i need to incress the cores to get more ram and if so can u tell me a...
The cpu speed does not affect the amount of usable RAM.
If the motherbaord is designed to take more than 4gb, it can be installed, but will not be used if the operating system is 32 bit.
To use more than about 3.5gb you have to have a 64 bit operating system. For example, my PC motherboard has slots for 8gb and I have 4gb installed, but the system only uses 3.25gb because my operating system is 32 bit XP.
Apr 22, 2014 | Compaq Computers & Internet
I WANT TO UPGRADE MY PROCESSOR. AT PRESENT MY PROCESSOR IS 2.2 GHZ. CAN I UPGRADE TO 3.0 GHZ.
yes u can but it totally depends on the motherboard u have at present so if it can support higher cpu u can upgrade it but u need to chk out first what max cpu u can put according to the board
Feb 06, 2011 | Computers & Internet
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
What is the max cpu i can put in my dell XPS 410
you can replace the max cpu power for your pc that is compatible to your motherboard or the cpu socket.
Dec 09, 2009 | Dell XPS 410 PC Desktop
I upgraded to win 7. did not back up my cpu. lost all toshiba settings and features got back eco mode, fingerprint scanner etc. all i need is high performance mode so i can run my cpu at its max....
check with the Toshiba website, got support then click drivers & downloads
put in the model number and see if there is any Win 7 drivers
Richard
Nov 12, 2009 | Computers & Internet
+12V DC Line voltage reading from PC burn-in test is low
if you really had that drastic of an issue, then the computer would not boot. this is some kind of mis-read.
Jan 13, 2009 | HP Compaq Evo d530 PC Desktop
Sorry for my bad english
Hi mastelmkd, click on this link;
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=499&maincat_no=1#menu
This is MSI's link for supported CPU's for the 645E Max-U motherboard. Check you're bios version. You'll need ver 5.3 to run the Pentium 4 (Northwood, FSB533, L2 Cache 512KB), Pentium 4, 2.8GHz CPU. Or you can choose a lower CPU from the list. Suggest you add the link above to you're favorites.
Good luck mastelmkd!
Mike
Aug 29, 2008 | MSI 645E Max-U (MS-6547-050) Motherboard
Max CPU for abit BL7-RAID
As number of cpus it supports maximum one cpu.
As cpu type it has a socket 478 supports any pentium 4 (not duo) up to Pentium 4 2.8G (p.n:RK80532PC072512)
You may need to upgrade bios to latest version to support the CPU.
Apr 09, 2008 | Abit BL7-RAID Motherboard
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Feb 25, 2008 | MSI 845GE Max-L (MS-6580-060) Motherboard
Cpu size
Hi handydak
For your Mobo
VKM400 AM-S Try this link it will tell you what max size CPU & Memory you can install to improve performance.http://download.aopen.com.tw/Default.aspx
Regards,
ajb2000
Dec 28, 2007 | AOpen vKM400Am-S Motherboard
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
