Question about Behringer Eurolive B212A Speaker
I have a Behringer b215a powered speaker that will not power on. I have replaced all 3 fuses, to no avail. The speaker is discontinued, and the newer model is b215d. I would like to replace all the back casing for the amp and power. Where can I find this part, or can I replace with the newer b215d?
  • Anonymous Jun 07, 2015
    Can I get a witness? I mean I need an AAAAAAAMEN!!! Not only do I need to save some money on these speakers that were priced closer to what speakers this size should cost, but I also need to save some money on the speakers I bought that were less money than all those money gouger speakers of the hour prices because one of them needs repair. AAAAAAMEN! lol... I guess I could just throw these away and stop caring about them. You know, Walmart style. I mean, who cares right?
  • Behringer Master
  • 2,825 Answers
Were the fuses blown when you took them out? Did it blow the new fuses too? If so, your internal amps are fried. They can be fixed by a technician.
Posted on Jun 08, 2015
4 Suggested Answers
  • 5603 Answers
SOURCE: Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
Posted on Mar 31, 2010
SOURCE: my Behringer B215A speaker shuts off after 5
In my B215 there demage HighFreq amplifier (TDA7293) after "CLIP" light on :(. I cant find failure... Anyone knows what wolud happened?
Posted on Oct 11, 2010
  • 5603 Answers
SOURCE: clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
How to replace Behringer Eurolive B215A Amplification
Is there any fuses inside the unit or just the one on the back inside that cylindrical fuse holder that you can push, twist and remove? Mine will not power and I want to open up the box if there is any fuses there and I will check for cracks near the pots, etc. as well while I am inside the power box. I already removed the box fromt heback. Just need to open it up now.
Apr 07, 2015 | Behringer Audio Players & Recorders
Remove woofer from behringer B215A
you want a woofer replacement? ... it's possible but you need to put whole your speakersystem in a program and the change you get the values you want is slittleeee. No if you need to ask if you have to change.... noooooooo. It's to complicated and only can ve done by peoples with real knowledge....
Apr 05, 2014 | Behringer Eurolive B212A Speaker
Tda7293 IC in behringer b215a keeps blowing, whats the cause?
Problem in the part of the power supply that feeds the tweeter amp. Fix the power supply and epoxy the board where it needs to be epoxy. Best of Luck! Serge Lavallee.
Dec 19, 2013 | Behringer Eurolive B212A Speaker
I installed a Q05-19700-00476 input PCBA for B215A componant. when I connect to the tweeter it blows it please help.
Certainly your hf driver is getting amp rail voltage, this is why tweeter blows, disconnect tweeter and with the unit powered on check the tweeter leads with a voltmeter and let me know the readings, but surely will be dc voltage...
Jan 02, 2013 | Behringer Eurolive B212A Speaker
I want to order a new volume pot for my Eurolive B215A powered speaker directly from Behringer, then fit it myself. Who do I contact to order the part?
Lots of luck. Behringer no longer sells direct. Fullcompass.com is their parts distributor. If they don't have it in stock, it takes months... I have had an order in for 6 months now. The procedure is you call Behringer at 1-425-672-0816 to get a part number and an incident type number. Then call Fullcompass and order the part at 1-800-356-5844 and tell them you need Behringer part. IF they have it in stock, then you are lucky.
May 18, 2011 | Behringer PA speaker Eurolive B212A
I have a behringer pmp3000 powered mixer and have had the output B to go out on it and we have not had it for 3 wks yet. previously we had a pmh3000 and have the same issue 3 times and decided to purchase...
With the failure in 3 wks, IMMEDIATELY take it in for warranty replacement.
Please read my tip on here regarding polarity difference of speaker cables when using Speakon to 1/4 inch plugs.
Any flakey thing in the sppeaker system such as cables, connectors, and the speakers can cause the problem.
Sep 19, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
B300 speaker blowing mains fuse as soon as power applied
The power transformers in these and some other behringer speakers have a habit of short circuiting.
Good luck trying to get any details from behringer about spares or tech info..they act like they have something to hide...and maybe they do ;).
You can unscrew the amplifier part from the speaker and disconnect all leads except those 2 going to the power transformer..if it still blows the fuse then the transformer is history.
Mar 21, 2010 | Behringer Eurolive B212A Speaker
Feb 09, 2010 | Behringer Eurolive B212A Speaker
Clip light
Nov 08, 2009 | Behringer Eurolive B212A Speaker
Behringer Eurolive B212A Speaker Logo
1,386 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
