Question about Westinghouse Apollo Elite 78180 Fan
I have burnt foil on the bottom of my new over how di I get it off
  • Derek
    Derek Oct 02, 2010
    Are you talking about a fan or an oven? I think you are in wrong category
  • 490 Answers
As it is metal, there really is not an easy way to do it. A heavy application of oven cleaner (not the low odor type) may be able to eat it loose. Be sure to ventilate well as the fumes are nasty. Otherwise, you must scrape it off or put a nice new piece of foil over it.
Farmerbear at Fixya.com
Posted on Oct 02, 2010
Didn't notice the do not use foil warning in the oven...so unfortunately it's really stuck at the bottom. Can the self-cleaning option work in getting the rest of the foil off?
it may but is unlikely as the self cleaning option raises the oven temperature to a point where the grease and fats are burnt off
unfortunately foil is neither of these
contact the manufacturer service department on line to see what your options are for this job.
Apr 23, 2015 | Kenmore Kitchen Ranges
Accidentally cooked with foil paper. Now my microwave oven is sparking. How can I fix it?
You could have burnt the foil into the bottom of microwave I would take a box razor and shave the area till there is no more foil melted in the bottom
May 07, 2014 | Samsung MU3250W Microwave Oven
How do you clean a convection oven with aluminum foil burnt at the bottom?
Hello,This is why we say no foil on the bottom...I would put it in self clean and see if it burns it off most of the time it will. You can take the two screws out of the back corners of the oven bottom and remove the bottom and soak it too. Hope this helps...Please rate me Thank You
Jun 09, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Bosch range model #hes236
there is no easy answer to this except elbow grease. however, i often put aluminium foil on base of oven with no problem. did you leave it there during self-clean when temp is very high?
Mar 29, 2007 | Bosch HES436U Electric Kitchen Range
Westinghouse Apollo Elite 78180 Fan Logo
61 people viewed this question
Top Westinghouse Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
Paul Bade
john h
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
