Question about Jenn-Air JES9860 Electric Kitchen Range
Oven stopped working on jenn air jes9860 aab. Control panel lights dimmed till they finally stopped working all together. after research, we replaced the clock/ control panel part. plugged it in, NOTHING. now what. this part was two hundred bucks and the dang thing still doesnt work. what the heck else could it be.
  • millacarver Oct 01, 2010
    The old one was completely out at this point as well. And there is zero response when putting in the new one. depressing. What else could it be.
    do we need to take the oven completely out and take the back off the check wires back there? Not sure where to even start. Not even familiar with a multi meter, thought i do have one.
  • Jenn-Air Master
  • 1,711 Answers
First you need to check the wires and wire plugs which are connecting the control. These multi wire plus sometimes thy might have one connection point that might be loose or even cut.
Second I did understand clearly. You mention that the first control was fading out but the new one is completely dead from the beginning. Try again the old if it is work at start and the fade out the new one is faulty.
Posted on Oct 01, 2010
  • espressonist
    espressonist Oct 01, 2010
    Then you must consecrate to the wiring. This is a very tricky situation. You will need very intensive visual check and multi meter in order to indentify which wire is not contact to the board. Also the wires might be damage or overheated in other point so you have to check all the wires at any point.
    As you understand is a time consuming procedure but the good thing you know for sure where to give all the attention.
    Please note that this happen once that the new board was damage also but this chance is only one in million.
  • espressonist
    If you want to try DIY the first start with thick wires arriving to the control board and see where they ends if you see and burn end, or even rusty contact, (once the wires arriving to the oven element were burn and rusty and when they replace the plug ends the oven control work fine) or two wires that their insulation look like it have been melt. Check this multi wire plugs remove them and see if the copper ends are all in the same line. If you have some experience and little luck you will find it. Otherwise you should ask a more professional to do it. But since you have arrived to this point you should give it a try. Unfortunately you cannot scan the oven so we can do it for you.
    Good luck you will need it.
My jennair burners ,fan and oven light work but
Replace the clock first(electric control) then test the oven it could be that it's why the oven does not work.
Jan 13, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it...
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Oct 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 Electric Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
