Question about Toshiba Satellite A105-S4244 Notebook
Power button wont turn laptop PSAA8U-1L052K n after it went into hibernate mode. just replaced ac adapter battery. need help!
jimbo6
  • 89 Answers
SOURCE: Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
Posted on Jan 14, 2008
pagebor
  • 2785 Answers
SOURCE: Dead
you better send your printer for sevicing
Posted on Apr 04, 2008
  • 36 Answers
SOURCE: Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
Posted on May 19, 2008
  • 95 Answers
SOURCE: wont shutdown or hybernate on ac adapter, ok on battery
You might need to do a system restore from an earlier time from tools menue in accessories/or use a recovery cd/or format your HD
Posted on Sep 14, 2008
gpetti2009
  • 92 Answers
SOURCE: toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=0&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Posted on Mar 29, 2009
Hibernation mode
First thing to try is to remove the battery and disconnect the AC adapter. Press the power button for a full 10 seconds to drain residual power from the capacitors on the board. Give it 5 mins then put the AC adapter and battery back in and give it a try. You might also refine your hibernation settings - I had a 5000 which is similar and finally turned hibernation off. Also check for a pin switch that the lid pushes down when it closes to see if something is holding the switch down when the lid is raised. I dont remember if that model has a mechanical push switch or a magnetic. Magnetic shouldnt do it but mechanicals are very prone to getting stuck.
Jul 02, 2010 | Acer Aspire 3000 Notebook
I ussually put mi laptotp to a hibernating mode but now I cant get it started the message it shows says: "hibernating" and its been like this for more than 3 hours How can I solve this?
Power off the laptop, remove the ac adapter, and remove the main laptop battery. Push the power button in for approx 15 seconds. This will bleed all power from the capacitors. Now, replace the battery and attach the ac adapter. Power the computer up. When it boots, go to the control panel > Power Options > On the top of the window you will see the hibernate tab, click on it and un-check the hibernate box. Hibernation will and can destroy parts of the registry. Sleep mode is fine for most laptops....hibernation is not.
Jun 30, 2010 | Dell Inspiron 1545 Notebook
My inspirion mini went into hibernate mode, and now won't restart. tried power button, light flashes 3 times but won't come on. tried pulling battery, no luck. Help?
Try this: Disconnect AC power, pull the battery, then press and hold the power button for 10 seconds. Release the button, replace the battery & AC, and try booting.
Mar 09, 2010 | Dell Inspirion Mini 10 Netbook
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
Wont boot up no matter what...just shows battery light and z lite
Remove the battery and disconnect the AC adapter. Press and hold the power button for a minute. Then connect the battery and AC adapter to turn on the notebook.
Aug 19, 2009 | Computers & Internet
My laptop has went into hibernation and shows a small moon and that the battery is in use. I took out the battery and it still shows it in use. It won't come out of hibernation and won't go back to...
The moon means Sleep or standby mode, if the laptop attempted to enter hibernation and sleep mode at the same time it could just be stuck in a hibernation loop and unable to load.
To test this, remove the battery and AC adapter, then hold your power button down for thirty seconds. Once you've done this replace the battery and power cord then try turning it on.
Let me know how you make out and if it doesn't work provide any other details you can including anything that comes on the screen and any beep codes you hear as it fires up.
Thanks and good luck,
Chris
Aug 10, 2009 | IBM ThinkPad T20 2647 Notebook
I own a Lenovo ideapad intel atom processor. It indicated low battery and when ac adapter is swithched on it went into hibernation mode. Despite trouble shooting as per the manual i could not turn on the...
remove battery ,check weather your laptop is on or not on adapter only.If it is not then there might problem with your adapter.Need to replace adapter.
May 03, 2009 | Lenovo IdeaPad Y510 Notebook
Dell 5160 orange light
I have never found hibernation to work successfully.
Disable hibernation if you ever get it started.
Try reading the manual on how to restart for hibernation, press "spacebar", "enter" or something.
Oct 10, 2008 | Computers & Internet
V5000 won't turn on now from hibernation mode
you might need to check your ac adapter and power outlet first before blaming your motherboard.
you go to hibernate mode because the battery is low. the battery is low because you ac adapter isnot supplying power to battery.
May 04, 2008 | Computers & Internet
Can't get it out of Hibernation...
my toshiba laptop went into sleep hibernation mode,& all i could get was the cursor on screen but nothing else, omg could not get it out of this mode for about 5-10 minutes,so i held the on/off button down for 10 seconds until it definately switched off,then was able to be reboot the laptop,but took some time doing this......
Oct 30, 2007 | Toshiba Tecra 8100 Notebook
Toshiba Satellite A105-S4244 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
