Question about Maytag Ovens
Have to replace the electronic ignator module in a maytag oven mgs5870adb. need to remove oven top
  • jphd03a Oct 01, 2010
    tks for copy of owners manual. need to know where ignator module is located in my oven and pls dont refer me back to manual
  • jphd03a Oct 02, 2010
    already have service manual for this model. It does not tell me how to remove top or where spark ignator is for this oven, pls get back to me. This is the third site ive been to and every one refers to manual without an answer!
  • 1,711 Answers
First you remove the four knobs. After the maintop assembly which is one unit. After that you will be able to clear see all parts including the ignator or spark module. It is secured on the metal base and you should remove the wires first.
Just take notes where each cable goes or you can take a photo to have it as a reference if you forget anything.
Put all back together in reverse order and is ready.
We have here the parts layout which will help you understand what is in you electric range.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46713&diagram_id=678713#d678713
Posted on Oct 02, 2010
  • 3,083 Answers
Go here for diagrams, parts lists, and manuals for your model oven:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46713&diagram_id=641258#d641258
At the end of the parts list, you can order a service manual, if needed, but you have to call the company.
Good luck, and hope this helps.
  • 17,970 Answers
This and other details could find below this link by the Maytag Service & Repair Manual
I hope helps.
Posted on Oct 01, 2010
Broiler wont work on maytag oven
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 27, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
F1 error code Kenmore Elite oven I have no owners manual.
Hi.
F1 means defective control module. On manual it will be: "Electronic oven control failure"
From manual:"Replace electronic oven control (also called EOC or clock)."
Try disconnecting power cord or tripping the circuit breaker for a couple of minutes. If the error comes back you will need to replace the oven control module.
Regards.
Ginko
Sep 06, 2011 | Ovens
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
The oven would not light, the broiler works and the stove top but the oven would not light up
the ignitor bar underneath the bottom of the oven bottom is bad and you need it replaced,remove the pan drawer to access the mounting screws and wires to it
Nov 26, 2010 | Maytag CWG3100A Gas Single Oven
Burner heads on my oven constantly spark. Think I need to replace electronic spark module in oven. No one can tell me how to get to this oart and what I have to remove to find it. All I get is copies of...
It is not the spark module and the part you need is usually found right behind the burner knobs...
here is a tip that I wrote that will explain this further...
Gas Range RepairBurners Keep on Clicking
heatman101
Oct 02, 2010 | Maytag Ovens
Maytag electri single oven, not getting hot enough?
replace the lower element. easy fix. TURN OFF POWER. remove two screws inside that hold element in place. Pull forward. disconnect clips that connect wire to element. reverse steps to replace with new element.
Feb 28, 2009 | Maytag CWE4800A Electric Single Oven
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Code F14
F14 is usually the fault code (open circuit) for the NTC sensor on the electronics module. I would suspect a bad connection from the oven temp sensor (located at the rear of the oven) to the electronics module. If you are able to remove the oven from the enclosure and remove the top and rear panels, (power disconnected!!) I would suggest checking all connections to/from electronics module. Also make sure door contact switches are secure and not loose (remove side panels) Oshie
Mar 22, 2007 | Gaggenau EB294/295 Electric Double Oven
Ovens Logo
101 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
