Question about Ovens
I need to replace the thermostat on my Kitchenaid range #KGSA906PSS00. What's the easiest way to get to it.
  • 1,711 Answers
In Your model the thermostat is electronic and is included in the electronic control board and it also have a separate temperature probe or jack probe.
We have here below the parts diagram which will help you understand where each part is located so you reach for it.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139479&diagram_id=952491#d952491
Posted on Oct 01, 2010
Kitchenaid range
The element is the first thing to check for continuity. Then there could be a burned off wire or terminal. the worst case could be a bad conrtol board relay if it has an electronic control or a bad oven thermostat or selectror switch if it doesn't have an electronic control.
Sep 01, 2014 | Ovens
We put our KitchenAid oven onto self cleaning mode, now the display is blank and the door will not unlock. It has been over 15 hours, and the oven is cool. How do we reset it?
Is this a built in wall oven or a freestanding oven/range combo?
If its a wall oven the problem is going to be a high limit thermostat that went out. If it is a older model the high limit t-stat has a red reset button that can be pushed and power will be restored to controls. If it is newer once the high limit goes out it needs to be replaced. Now heres the tricky part on wall ovens, the high limit thermostat is inside control panel and it needs to be taken apart to get to that t-stat and that can be a problem trying to get it pulled out enough to get to control panel with the door being able to open. On that i wish you luck
Thier is also a high limit on the freestanding range its going to behind the back panel and easier to get it since your not dealing with something built into a cabinet
Good Luck,
Gene
Aug 18, 2011 | KitchenAid Ovens
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
My display reads F5:E7 on a Kitchenaid Superba stove. email cmaffey@hotmail.com
Well, its 10:30 on a Saturday night, and I was so frustrated by my Kitchenaid Oven. I set it to clean, but afterwards it would not unlock. the display read F5:E7, which i found out means the door unlocker won't work.
So, how did i fix it, well there are two ways, to get your oven door open.
I only found this out after tinkering for 2 hours, and found the easiest way to get your oven going again:
Pull your range out so you can see behind it. You will see a rod in the upper center part of the oven. There is a cutout in the metal and you can see the solenoid that locks the oven. It is connected to a rod. This rod is what goes to the front of the oven and is what is keeping your door locked. Simply move that rod the opposide direction, it will click, and presto, your door is now open.
I never bothered to replace the solenoid, because I didn't know if it was bad, or the controller board. The Solenoid itself is $90, I don't want to even guess what the control board is.
So, not technically a fix, but it will get your oven open. Just don't clean it automatically any more!
Sep 30, 2010 | KitchenAid Ovens
It takes so long for my Kitchen Aid slide in range to preheat
Could be a faulty element or faulty thermostat. Both will need to be tested to see which is problematic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 31, 2009 | KitchenAid Ovens
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Will not come on after self cleaning
this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
**FIRST unplug from the wall or shut off the breaker**
*the other issue is not knowing what model you have.
I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
hope that helps,
good luck
Sep 28, 2009 | KitchenAid Ovens
I have a KEBI17DBL8 Oven that will not work after using the self clean cycle. Should I get the thermostat replaced or but a new oven?
No, no need to get a thermostat or replace the unit...yet.
sounds like a tripped hi-limit thermo.
that model number looks like a double oven wall unit, correct ? if so, big job. if not awesome. if it is, it's hard only because these are heavy. (alot of techs like myself have "wall oven carts" that allow me to remove it fairly easy) you might not have to pull it out though if it's not a wall oven, my bad.
however, I think it may be the older unit's manufactured by "Dacor". if so the limit switch on most of those ranges is a "non-resetable" style. meaning you'll have to replace the themal cut-out or aka thermal switch.
*FIRST, unplug the unit or shut off the breaker.
the hi-limit is located by the latch/lock assembly, so you'll need to dismantle the unit to a degree. if it's a free standing range, it's pretty easy. lift the top and the latch/lock access panel is located right there.
you'll need to determine the "why" as well of course. did the cooling fan/blower fail (#4173004), or the cooling fan therostat (#4173008) ?
the part number you'll need for the thermal switch failure replacement is #814505. check the old one by ohming it out first of course.
hope that helps,
good luck
Sep 26, 2009 | KitchenAid Ovens
Kitchenaid oven says Error code F3E0, oven sensor-upper what'sup
It means the sensor that lets the thermostat know what the temperature of the oven is has failed. You need a new sensor.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
From KitchenAid themselves
F3 E0
Get one from the people in the first video. Very easy fix.
https://www.youtube.com/watch?v=VZKHpduF9RI
kitchenaid oven temperature sensor replacement Google Search
Sep 17, 2009 | KitchenAid Ovens
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
