Question about AllStart Products Allstart Battery Electrical Tester
My all start sport pac generator will not hold a charge. the red light will come on for a half a second and then will go off when i plug it in. any help is appreciated. thanks, bryant potts
Headset will not re-set according to instructions. Indicator light is half red, half blue. What should I do?
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
Oct 14, 2015 | AUVIO Bluetooth Headphones
Have a B&S VOX 6500 industrial generator with Honda motor. Generation quit and no breakers flipped. voltmeter shows 3.4 volts on both legs when running. What happened? and how do I fix?
It may be just as simple as flashing the fields. Remove the end cap of the generator. Look for the brush holder on the top center of the housing The brushes may be worn out or the fields may have lost the residual magnetism. The brush holder has two wires going to it, a red (positive) and a ?white (negative). Hook a couple of wires to a 12 volts battery. Plug a lamp into the generator that will light up when it begins to charge. BE VERY CAREFUL!!!!! Start the generator and momentarily connect the two wires to the brush holder connections. Make sure you observe the polarity Two or three seconds is plenty. If this doesn't work remove the brush holder and check brushes.
Dec 17, 2014 | Honda Electrical Supplies
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Booster pac,ES5000,charge light not coming on,why?
do you want auto brake boosters? or only for camera,
if you want auto brake boosters ,we can help. regards
Aug 24, 2013 | Solar ES5000 Portable Battery Booster Pac...
The red light above the chatging plug stays red when I am charging the computer. is it supposed to be this way?
Try removing the battery, hold the start button for 10 seconds, then reinsert the battery.
Feb 07, 2013 | HP Mini 110-1037NR Netbook
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
I just got a Marlboro Power Pack too and have not idea how to charge it. It came with a corn with a cigarette lighter plug at one end and a negative and positive plug at the other end. what does this...
The pac will have a door on both sides that hide the cables you hook to a battery to help jump start a car once it is charged up. The cord that you say has a cig plug on one end is used to charge it using your car plug. There is another door on the back of the Pac that holds all the accessories, extra fuses and the charging cords. It does not sound like you have the A/C adaptor to plug it into a wall outlet.. If this unit is old the internal battery may be bad these Pac's are notorious for battery failure. You can find these batterys on eBay for about $13.
Nov 12, 2010 | Garden
I have a Sport Pac portable power generator that will not take a charge. I have been unable to contact All-Start.
It is likely that the internal nickel-cadium batteries need to be replaced, (it's usually less expensive to replace the whole unit).
Mar 12, 2009 | Electronics - Others
Ipod battery will not charge
Reset it. Turn the hold key on and off then hold the central button in for 10 seconds.
If this doesnt fix it send it back to apple by getting a box sent to your address from the apple website. *sigh* This is why I got rid of my ipod, Too many problems and 9 replacements.
Jun 15, 2008 | Apple iPod nano 3rd Generation
NiCad battery not charging
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Oct 23, 2007 | Metz 60CT-1 Flash
AllStart Products Allstart Battery Electrical Tester Logo
91 people viewed this question
Top AllStart Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an AllStart Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
