Question about Performance Teknique ICBM-782 Car Audio Amplifier
Protection lite raed - Performance Teknique ICBM-782 Car Audio Amplifier
The bark of a small citrus tree (oranges 1.5m high) where eaten all around by a pet (ra (rabbit), how can I fix it?
If eaten all the way round, you can't. The tree will die. You need a new one and a protective cage around the trunk.
Dec 17, 2017 | Garden
What is the difference between osteoarthritis and rheumatoid arthritis?
Osteoarthritis (OA) is a condition that affects the whole joint including bone, cartilage, ligaments and muscles.
Osteoarthritis may include:
  • inflammation of the tissue around a joint
  • damage to joint cartilage - this is the protective cushion on the ends of your bones which allows a joint to move smoothly
  • bony spurs growing around the edge of a joint
  • deterioration of ligaments (the tough bands that hold your joint together) and tendons (cords that attach muscles to bones).
Rheumatoid arthritis (RA) is an autoimmune disease that causes pain and swelling of the joints. The normal role of your body\'s immune system is to fight off infections to keep you healthy. In an autoimmune disease, your immune system starts attacking your own healthy tissues. In RA, the immune system targets the lining of the joints, causing inflammation and joint damage. RA usually affects smaller joints, such as the joints in the hands and feet. However larger joints such as the hips and knees can also be affected.
Sep 02, 2014 | Miscellaneous
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
Alesis RA 500 makes a "clicking" sound and no more sound. later it will "click" on again
Clicking sound is a protection relay. This means one of the power amp sections have failed. Or that your speakers connections are faulty
Sep 24, 2010 | Alesis RA300 Amplifier
Audio problems with Alesis RA-150
on bridge mode the speaker impedance should be 8ohms, less than this clipping will happen. try bridging two 4 ohms in series.
if this happens without speaker connected, u have a power amp section that is trying to draw more power than it can handle.
as for the second check connections first, otherwise i suspect u have a defective power amp for the right channel.
Mar 12, 2010 | Alesis RA-150 Amplifier
I bought a ra(ndsl/nds ) for my ds lite and
Mine works fine!!
Download English 1.18 from the R4 website.
Unzip
You should have 4 files on your card
_system_
moonshell
_DS_MENU_DAT
_DS_MSH_NDS
you then add the .nds game files from wherever you get them from
Make sure the card is formatted first, ie there are no other files on it. try FAT. rather than FAT 32. I can't remember which but I've had no problems with either the card or the software, best thing since sliced bread, and it only cost me a tenner.
Dec 19, 2009 | Nintendo DS Lite Console
I need manual book and driver for this mobo...
I can give you this only
http://rapidshare.com/files/ 254493533/U.D.Scanner.2009.2.0.0.62.ra
please VOTE 4 ME
Sep 25, 2009 | Lite On NA115 Motherboard
Menu data not found
You need another program to run from an R4 Search google for "DS hacks".
Jan 04, 2009 | Nintendo DS Lite Console
What items do I need to download games on to my Intendo DS Lite.
I have an ra card that says no disc is needed but cant get games to work I have unzipped but ds menu data not found keeps comming up
How to remove write protect on my usb flash drive
Im guessing your using a micro SD or SD card
and there is a lock Lever on the left side of it.
Simply unlock it
Oct 06, 2008 | Nintendo DS Lite Console
Performance Teknique ICBM-782 Car Audio Amplifier Logo
23 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
