Question about Refrigerators
Noisey fan stops when door opens - Refrigerators
  • 1 more comment
  • hunglee27 Jan 04, 2009
    I have the Samsung RS2556SH, 4 years old. When open the door, "fan noise" is stop. When close the door, "Fan noise" making noise. I turn off the power for 15 minutes and turn on again. It stop making noise for a few hours and then making noise again. Really frustrated, if you have the same problem and had been successfully fixed it, please provide a solution. thk.
  • lianefree Mar 22, 2009
    LG LFX25960 is making freezer fan noise when door is closed. i think ice build up inside of fan area when humid in the room. I have turned of for 8-10 hrs . sometimes, works OK most of time does not fix it.
  • sallymt May 01, 2009
    I have a GE Profile side by side refrigerator and it makes an annoying humming noise.  When I open the refrigerator door, it stops.  I think it is related to getting stuck in the express thaw function.  I will cycle through the express thaw settings to turn it off.  When I open the door, the 3.0 light is on and it constantly hums when the door is closed.  Can anyone help me solve this problem?  This refrigerator has been a big disappointment.
  • 828 Answers
Fan is supposed to stop when the door is opened . Noise from the fan could be a bearing problem if it is a high pitched squeal. If this is the condition you have , replacing the evaporator fan should correct the problem. If the fan is sounding like a buz-saw the fan blade could be pushed in to far on its shaft, or it could be hitting an ice build-up in the blade turning area.
Posted on May 26, 2008
Thank you Mr. Guru. I follow your solution and the problem is fixed.
I removed everything inside the freezer and refrigiratoor then turn off the refrigirator for over 24 hrs. I believed all the ice which build up in the fan is completely melted. The fan run smooth now.
Thanks,
Hunglee27
Posted on Jan 11, 2009
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: fridge fan has frozen and has stopped. was noisey
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
Ariston fridge/freeser BCB31AA
Call out the warranty supplier. Where is the noise coming from? If no warranty, check the electrics to the compressor and fan. sometimes the noise is the fan. Also switch off overnight and leave doors open. When restarting, if the noise has gone it will have been the internal fan hitting on ice buildup.
Mar 25, 2014 | Freezers
Noisey laptop fan
Clean fan and vents. You may have to open the case.
Dec 25, 2012 | HP Pavilion dv6305us Notebook
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
I have an AEG competence 5020 B fan oven (single) which has a very noisey fan, does this need a new motor and can I fix this myself?
ISOLATE THE MAINS POWER BEFORE OPENING THE REAR OF THE OVEN.
Remove the oven, open the back, remove the fan, and clean with WD40, afer the fan is dry, fit the fan back into the housing, replace back and put into cabinet, switch on low, if the fan makes a whirring noise, or unusual squeeking replace the fan, if however the fan sounds normal and good pressure when door is open, it should be okay. If you require a part go to whitegoods.co.uk
Hope this is helpful
johnf1
May 17, 2011 | Ovens
Fridge fan has frozen and has stopped. was noisey and stopped when door opened
heatman101
Oct 12, 2010 | Samsung RS2534 Side by Side Refrigerator
Makes noise stops when freezer door is open
s this sound like a noisey fan . if older model i would replace the fan motor . / other problem could be the fan blade has moved on the motor shaft . so just replace the fan balde .. mm
Aug 10, 2010 | Maytag MBB1956GES Bottom Freezer...
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Fan oven is noisey
needs new fan motor unless the old one is loose
Dec 11, 2008 | Tricity Bendix SE454 Electric Kitchen...
No water at door and evaporator fan noise
I had the same water problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
http://www.fixya.com/support/t1247133-no_water
Copy paste link.
Dec 02, 2008 | Hotpoint HSS25GFP Side by Side...
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Refrigerators Logo
1,067 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
