Question about GE WSXH208A Front Load Washer
GE Front Loader Washer
My washer will fill but will not spin at all, I can hear a hum noise, like the motor is running and the belt is fine. What is my problem please or some ideas to check?
I also have a leak when it goes into final rinse. Any idea to a solution for this?
  • Anonymous Jun 04, 2008
    i have a front loading washer that will only fill or drain, controle timer button will not advance and hums, front door latch light is lit.
I have a front loading g.e. washer, will fill and drain, knob will not advance and makes a humming noise, indicator light for door latch is lit
Posted on Jun 04, 2008
  • 868 Answers
Door latch is sending false signal to control board,first replace the door latch.
Posted on May 26, 2008
2 Suggested Answers
SOURCE: Ge prodigy wpse4270aoww won't rinse or spin
if basket wont spin, remove front hatch by inserting spackel knife to trip spring latch on both sides,then check the belt for wear & tear.factory length is 29.5 " time will stretch them out, resulting in broken belt.check behind control panel hatch for diagram of machine for exact location of belt also can be downloaded online.
I hope this helps.ie overloading machine will shorten belt life.
Posted on Mar 07, 2008
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
Jul 30, 2014 | General Electric Gfwh2400lww 4.9 Cu. Ft....
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
My washer are not spinning,i can hear the humming noise.could it b the motor?
Is it a front or top loader? Did you check the belt? Does it wash but not spin? I could go on like this.............
Aug 09, 2011 | Maytag Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
TOP LOADER KENMORE WASHER FILLS UP BUT DOES NOTHING ELSE.
Sounds like belt is broken. Open front cover and look at belt, if broke replace. If not broke try unplugging for 2 minutes, plug back in then open and close lid 7 times slowly, this should reset the electronic motor.
Jun 05, 2009 | GE WBSR3140DW Top Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
GE WSXH208A Front Load Washer Logo
346 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
