The player cannot play
I insert the dvd, and it show loading but nothing happen,after a couple seconds it say no disc. Can you help me with this issue... Thank, rossy
  • bobsjoy May 26, 2008
    i have the same problem and was told my drives are bad
  • 3,037 Answers
Sounds like you need to clean the laser lens. If you have a cleaning DVD use that first, they can be bought at stores that sell dvd players or like a best buy or walmart. if that doesn't work, try opening up the player by taking off the outer panel and cleaning the lens with some isopropyl alcohol and a q-tip. Let me know how this goes and whether you have any questions or need any more help with this. good luck
Posted on May 26, 2008
When I insert a DVD to play it will not play. On the dvd screen it only shows "LOAD" and after a while it will eject the disc.
If it happens with all discs, the motor "spin-up" system is broken. Best to buy a new one.
Aug 19, 2010 | Samsung DVD-R135
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
the lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Apr 29, 2010 | Akai DVDP5851 DVD Player
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Apr 18, 2009 | Televison & Video
Ps3 game loading
unfortunately your bluray laser has probably failed. the diode burns out quickly on these older units. call sony they charge 150 or send it to me for 100..24hr turnaround
Oct 31, 2008 | Sony PlayStation® 3 (60 GB) Console
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
