Question about Garden
Briggs engine,carb on tank. runs on prime only ,replaced diaphragm, carf body had internal corrosion, model 130212 type 1815-01, on log splitter, won't **** gas???
  • Max G Schoenfeldt Oct 01, 2010
    Briggs motor-130212-carb over tank-no float bowl-has diaphragm to bring fuel up to carb tube- replaced diaphragm and smoothed contact surfaces with fine [600 grit] paper-runs for a few seconds with a prime-had some corrosion on diaphragm contact surfaces???
    President:
  • 1,509 Answers
I don't know how you installed the daiphram, but I remove the carb with the tank attached, then I take the tank off. with the tank off and the diaphram removed, I dump the tank out and then blow it out with compressed air, then I put in a little gas and afew driveway stones ( as big as will fit ) put the lid on and then holding my fingers over the holes give it a nice long shake. 10 minutes or so. Dump out the gas and the rocks and take a look in there, still don't look like new? do it again till the gas you dump out looks like it's clean. That little pocket in the top of the tank is where the main jet gets it's fuel make sure this is clean too. the diaphram pumps gas into this pocket and then the main picks it's fuel from have the extra just overflows back into the main tank, The main should have a screen around it and you can remove it clean it and put it back on you should be able to blow though to the inside of the carb though the main. once it's all clean make sure the spring that rests on the diaphram is in place and put the tank back on the carb put gas in the tank and shake it up, ( fills the pocket ). put it back on make surethe gasket still seals ( it's OK to rese it just seal in on if it's firred up) it should start right up as long as the plug is clean and it's firing.
Posted on Oct 01, 2010
  • 1,040 Answers
Here is a link to a couple of my Tips. And even though they are for weed eaters and such, the same concept applies to your carburetor. The key to carburetor cleaning is the Den Tek Brush!
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
And depending on how bad your corrosion is, you may end up needing to buy a new carb. Corrosion may keep the parts from moving freely; such as the float.
Good Luck!
Jim
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
My MTD 662A is not priming what parts will I need to replace
what engine is fitted to this machine? if its a briggs & stratton sprint or cassic ( platic carb fixed to the tank ) then you will need to remove the carb/tank assembly from the engine. Remove the 5 screws from the carb and remove it from the tank. check the the long white pick up tube hasnt got debris stuck in the gauze. at this stage if you have an air line then drain and blow out the tank, gently blow out the pick up tube and main jet (will have a gauze sleeve over it ) and you will need a new diaphragm kit, these are very cheap and can be bought easily from ebay etc briggs & stratton part number 795083 or 495770
Mar 09, 2015 | Mtd Garden
My b&s 6.5hp log splitter wont stay running unless i spray gas directly into the carb... this is where it's get funny, i took a carb off my
If your gas is E-10 then there is a strong possibility that the line from the tank is blocked, also could be a filter and even sludge in the gas tank all caused by E-10 seperating and becoming thick.
Sep 11, 2012 | Briggs & Stratton Briggs Stratton...
Describe your Briggs Stratton Lawnmower Lawn Mower Short Block Problem. I have model# 11A-414E765 Lawn Mower. Starts ok but is surging and when I checked a brand new spark plug it was full of black dust...
I am pretty sure this is a 4.5 Hp engine with the carb on top of the tank. Plastic carb 4 or 5 mounting screws mating carb to tank. Remove the air cleaner... and tighten the carb to fuel tank mating screws. It is drawing air between the tank and the carb. This should stop the surging. If is has been a long period that you used the mower with the surging problem the diaphragm between the tank and the carb may be either out of position or damaged. The diaphragm is not expensive. Usually the first time this symptom presents itself you can resolve it by tightening the carb to tank scresw. IF you have the primer bulb carb..mash the rubber of the bulb against the carb body. If the surging stops... the primber bulb has a pin hole in it.
You passed the mower model number and not the engine model number. When we use the 11A number you passed all we get is the base and handle parts. If you need more help I need the model number off the engine just above the spark plug wire on the air shroud.
Thanks for choosing Fixya,
Kelly
Aug 31, 2011 | Briggs & Stratton Briggs Stratton...
I have a morrison classic 35 that is surging while its running, it runs well except for the surging. am guessing plug gap is 20thou and have cleaned everything. it seems to be the arm that comes off the...
Your Briggs & Stratton Classic engine uses a diaphragm to pump fuel. Yours has deformed and needs to be replaced. It is a very easy repair. Remove the air filter. There is a bolt on the end of the fuel tank nearest the spark plug. Remove this bolt. There is another bolt just behind the carburetor that holds the tank to the engine. Remove this bolt also. Now you should be able to gently pull the tank away from the engine. After the carb clears the intake tube, you can tilt the tank enough to remove the governor linkage from the carb butterfly shaft. Now the tank/carb assembly is loose and in your hand. Go to the workbench. There are 5 screws that hold the carb to the tank. Remove these 5 screws. When you lift the carb from the tank, you will see the diaphragm gaskets. Remove the old and install the new set. The 2 part diaphragm set consists of a rubber diaphragm and a paper gasket. The rubber part goes against the tank, then the paper gasket, then the carb. Leave the screws in the carb as you reinstall it, and the screw tips will align all parts during reassembly.
The diaphragm set is readily available at any Briggs parts dealer or online. Make sure you take the Model, Type, & Code numbers with you when you go for parts. These numbers are stamped into the metal fan shroud just above the spark plug.
Dec 31, 2010 | Briggs & Stratton Garden
The engine starts ok but it keeps revving up and down, as though its about to conk out, although, so far, it hasn't. It has also started to blow out some white smoke? I have changed the spark plug - but...
Your Briggs & Stratton has a Sprint or Classic motor on it. Every few years, the diaphragm in the carburetor must be replaced.
Briggs part #495770
1. Remove the air filter assembly. This is a good time to clean and re-oil the filter.
2. Remove the 3/8" head bolt from the front of the fuel tank.
3. Remove the 1/2" head bolt from the side of the fuel tank.
4. Gently pull the fuel tank assembly toward you and tilt it away from you. While doing this, you will need to unhook the governor wire from the throttle plate.
5. Drain the gasoline (you can use it again later)
6. Remove the 5 screws that hold the carburetor on top of the fuel tank.
7. Pull the carb straight up. Be careful not to lose the spring or strainer on the bottom of the carb.
8. Remove the diaphragm.
9. Clean the carb and tank surfaces with carb cleaner spray.
10. Open the package with the new diaphragm in it. You will find 2 pieces. One is rubber, the other is paper.
11. Place the rubber diaphragm onto the fuel tank, then the paper one. Gently reinstall the carb onto the tank.
12. Push the 5 screws back into the carb. Before you tighten any of the screws, have all 5 pushed through and wiggle the carb a little, this will allow the diaphragm to align properly. Tighten the screws.
13. Reinstall the tank/carb assembly. Make sure you hook up the governor linkage.
14. Inspect the governor spring(s). They should be connected on both ends. You should not disconnect them for this repair.
15. Reinstall the air filter, gas, prime, and GO!
Good Luck!
Oct 25, 2010 | Briggs & Stratton Garden
I have a Briggs & Stratton 5HP Engine (Horizontal shaft) And it has the diaphragm carb on it. The last person to own it messed with the carb adjustments and it'll have trouble starting and idling...
2 turns out should get ya started adjust from there. If adjusting doesn't help you may need a new diaphragm. While you have diaphragm out blow through the 2 holes you'll see under diaphragm with air to hopefully avoid pulling carb off to clear screens on pick up tubes. Also check carb mounting screws through carb into tank. They frequently come loose on chippers and log splitters because of hard mount.
Oct 07, 2010 | Mtd Heavy Machinery
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 13, 2009 | Craftsman Garden
The mower sounds like its dying.There are two springs on the carb that are floppy, but not broken.Should there be three?
Is this a carb-on-the-tank Briggs & Stratton engine? If so, replace the diaphragm between the carb and the tank.
Oct 17, 2009 | Champion International Champion& Small...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
