Question about Lexar Professional High-Speed 2GB Secure Digital Memory Card
SDHC Card 4GB
My Computer does not read the card. Can the card be difective, or is it my computer?
  • 4 more comments
  • rosemarie_w Aug 04, 2008
    when inserted in the camera will not format. how do we format the disc? we have a lexar 4GB SCHC card and the Kodak easy share CX530 camera. please help us.
  • Anonymous Oct 01, 2008
    I can not get the card to read on one of my computers, it happens to be the one I use for all photo needs. It will download to my laptop with is newer. How can this be solved?
  • pooface Nov 11, 2008
    I have the same problem as well. The card won't format in my camera. It comes up "card needs formatting", I hit continue, and it comes up again after a minute. Also, every desktop computer I try won't read it but a laptop will.
  • Anonymous Dec 24, 2008
    I have a kodak 8.2 megapixel camera with a kodak 4gb sdhc card. When I put this in the card reader on my Acer 5100 laptop computer to get the pics it will not read the card. Is the problem in my laptop, Can any downloads be done to fix this problem or do I have to take it to a teck for help
  • rjdelaossa Dec 28, 2008
    Lexar 4gb schc premium 60x, computer wont read but it will with other sd cards just not the lexar one i have... I just locks up my computer window but as soon as i remove it from the multi-card reader (built into my computer) everything goes back to normal instantly.
  • sunnergren Mar 08, 2009
    Computer will not read Lexar 4GB sdhc card without cable connection. Also did not record Raw files from camera.
  • 55 Answers
The card can be defective but it should read it. its probably dust or somthing stuck between the card and computer.
Posted on May 28, 2008
Why isn't my computer reading my micro sdhc card in a sdhc adapter, yet when i plug in a 'normal' sdhc card' it appears in my computer
The PC should be able to see 32GB.
Before the adapter, the first thing to check is the driver for the card reader.
The next most likely: the adapter is bad.
This is also a common problem
Jul 28, 2015 | PNY 32GB MicroSDHC Class 4 Memory Card...
My computer wont read my sdhc 4g sandisk card
Not all card readers, devices and computers can read the high capacity format, however. If you are getting a read error, it could be that your reader is not SDHC compliant. If this is the case, your device should read 2GB or smaller cards, but respond with an error for larger capacity cards.
Apr 24, 2012 | SanDisk 4GB microSDHC Memory Card
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
A memory card in a digital camera can be read in the camera but not in the computer
My guess is that you have an SDHC (Secure Digital High Capacity) card in the camera, but the card reader attached to your computer can read only the older SD cards. SD cards that are 4GB and larger are SDHC types, and should have SDHC prominently displayed on the label. The card reader on the other hand, was probably made before the SDHC type cards were ever made.
You can find a new card reader that support the high capacity cards for under $20 in many places. Unfortunately, the older card readers can not be upgraded to read the newer cards - but the SDHC readers can read the older SD types.
Sep 30, 2009 | Kodak EasyShare Z740 Digital Camera
Have a pny micro sdhc 4 gb disk that is not being read by my computer?
From your description, it sounds like the card is faulty, not the computer or the card reader. If you can't get the card to read or write in any device now, then it's probably dead. Is the card reader you're using an SDHC card reader or just a regular SD card reader?
May 14, 2009 | PNY 4GB Secure Digital High Capacity...
Acer aspire 5570 won't read sdhc memory card
Good morning! please try to review the operations manual of your acer aspire 5570, which we can found details of what memory card type/capacity it will support, also there might be set-up settings to be done in your computer motherboard to recognize the 4gb sdhc memory card. best regards.
May 02, 2009 | Computers & Internet
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Lexar Professional High-Speed 2GB Secure Digital Memory Card Logo
526 people viewed this question
Top Lexar Electronics - Others Experts
downhille
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
