Question about Spidem Trevi Digital Coffee Maker, Espresso Machine
Need to learn about the electrical system. My coffee machine does not turn on,
  • 1,089 Answers
There are 2 reset buttons on the side of the boiler if you have the neew J boiler.
If you machine is older, there is a reset button in the back of the boiler towards the bottom of the boiler. Push in between the 2 wires on the black thermostat on either boiler. Its harder on the J boiler because the thermostats are between the boiler and the side of the machine.
Posted on Oct 02, 2010
  • caffine craz Apr 11, 2012
    Thank-you for the solution!
Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
May 21, 2009 | Waring Pro® WC1000
Tip
My coffee is weak.
Checkif water is dripping right at the center of the filter, if it isdripping on one side because the orifice is clogged, that can result inweak coffee.
Ensurethat you are not leaving the machine brewing for a time that is toolong, and Italian coffee cup is very small, approximately one regularshot.
Thisare the trickiest ones, you need art and practice to get a goodespresso with a Moka, but when you learn, the result is better thanwhat you may get with an home electrical espresso maker.
The frameon the hob must be not too strong, and the mixture coarse but wellpressed, with water at level tag, or you will get a weak coffee.
on Apr 01, 2009 | Bunn NHB Coffee Maker
Coffee has started becoming weak
Apr 21, 2009 | Bialetti Mukka Express
Coffee is cold and not brewed properly. Unit has been cleaned,de-calcified, rinsed, but still the coffe is cold. temperature is set to high, and the machine can produce steam. Anyone help?
Apr 02, 2009 | Gaggia Titanium Espresso Machine
Coffee out of the machine seems too watery
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
Doesn't heat the water
Jan 27, 2009 | Nespresso C100B Essenza Single-Serve...
Saeco Professional- Coffee taste watery and not creamy
Nov 23, 2008 | Saeco Royal Professional Espresso Machine
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Weak coffee
Jun 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Weak Coffee
Mar 02, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Spidem Trevi Digital Coffee Maker, Espresso Machine Logo
1,553 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
