Question about Brother IntelliFax-2820 Laser Fax
I just purchased an intellifax 2820. I cannot send a fax out of state. I can send in the state. What could the problem be?
  • 2,460 Answers
Plug a regular phone into the fax jack and dial an out of state long distance number. If you listen carefully, it will probably tell you that you have not selected a long distance carrier. For fun, you can also dial 1-700-555-4141 and listen to the "no pic" message. Now call someone and get an LD carrier.
Carl
Posted on Oct 01, 2010
  • 6 more comments
  • Carl Navarro
    Carl Navarro Oct 01, 2010
    ??? No feedback?
  • sandywinchel Oct 01, 2010
    I already have time warner for local and long distance. This new machine is replacing a machine that was already there. There is probably a set up problem, but i cant figure it out.
  • Carl Navarro
    Carl Navarro Oct 04, 2010
    In any fax machine I have owned, there has NEVER been dialing restrictions. So now, it still goes back to the orignal question, "What happens when you put a regular phone on the line and dial out of state calls?"
    TW Business class sells phone lines based on calling patterns and they tend to make fax lines in-state or local only. It just might be that they also restricted long distance by mistake.
    That's why you need to use a regular phone on that line and test it yourself. The 2820 manual hos no "special" restrictions in the setup menu.
  • sandywinchel Oct 04, 2010
    This is a replacement fax for one that was already there. The problem is in the setup mode.
    or handshake. booklet doesn't give instructions on the ecm set up
  • Carl Navarro
    If that's true, then send me a fax. 815-550-2923
    I cannot send to that area code. It is out of state. The fax dials the number but does not connect.
  • Carl Navarro
    Please call TW customer support. Tell them exactly what is going on. ECM is fax-to-fax info that is only transmitted if BOTH machines have it. In your case, it's not getting that far, especially since you can't send to me and mine is just a run-of-the-mill fax server in Suburban Chicago. You either have a bad machine or it's still TW's problem. So, either exchange the machine, or deal with TW. Keep in mind that if your SECOND Intellifax does the same thing it IS Time Warner's issue.
  • Carl Navarro
    Carl Navarro Oct 10, 2010
    How's that replacement 2820 working?
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
Whenever I send a fax on my brother intellifax 2820 it feeds crooked, I can not get it to go in straight. Therefore, the receiver only gets half the fax.
what you will need to do is go to a hardware store and purchase some isoprophyl alcahol. put some on a rag and clean the paper feed rollers if that fails there must be some in side that area like a peice of paper, try cutting a file folder to 8x11 in manually force feed thru a the paper feed section. good luck brother tech
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
may be you have a phone line problem
Intellifax 2820?
Yes it can.But if you do manual faxing it only fax one by one.
Oct 29, 2008 | Brother IntelliFax-2820 Laser Fax
Sending and receiving faxes on legal size paper.
There should not be a problem with TX on LGL paper. If you want to configure the machine to recieve LGL on a regular basis: Press "MENU" 1-3. Then use the up/down arrows to select LGL. "MENU", "EXIT". That should do it. Good luck!
Apr 20, 2007 | Brother IntelliFax-2820 Laser Fax
FSending and receiving faxes on legal size paper.
Press Menu/Set, 1, 3 Press up or down arrow to select Letter, A4, A5, A6, B5, B6 or Executive Press Menu/Set Press Stop/Exit :o)
Brother IntelliFax-2820 Laser Fax Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
