Question about Kirby G4 Bagged Upright Vacuum
Fan replacement gone bad!
I tried to replace my fan, but I stripped out the spot where you put the wrench on the motor armature. Once I knew that was ruined, I put vice grips on it just to remove it, but it still wouldn't come off! I know I have to replace the motor armature now, but I still can't get the front shaft to unscrew. BTW, I'm turning it to the right.
Any suggestions?
  • 1,673 Answers
I take it the armature is not moving at all when you are turning the pulley(to the right, is right). You may have to pull the motor asm. out, remove the 4 scres and nuts off of the front bearing plate and pull it out along with the armature. I can't rmember if there is enough romm after pulling it out, from the inside to cut the shaft off with a hack saw. It is either that or replace the front bearing plate along with the armature.
Posted on May 26, 2008
How do i replace the fan on a riccar rsl3 vacuum cleaner?
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
How to remove a Kirby Heritage II Armature
The armature that holds the fan on is reverse threaded. It turns to the right to remove it. You can put a nail or nail punch in the hole on the armature and tap it gently to the right. this should loosen it enough to unscrew. There's a washer, then the fan, and a spacer that fit over the shaft.
Sep 02, 2012 | Kirby Heritage II Vacuum
Motor on Eureka vaccum is suddenly very loud. I've changed all the filters and the belt.
The likeliest causes would be a large item sucked up and into the fan, causing a loud rattling noise, or a piece of the fan broke, resulting in the same noise. This means replacing the fan assembly.
The armature brushes could also be worn down to the point of causing the brush holders to contact the armature, which will, and probably has, ruin the motor. A replacement of the motor is necessary.
Cost of repair/replacement would probably be higher than the vacuum is worth.
Jan 03, 2011 | Vacuums
How do you get to the fan on the generation 3 kirby
First remove the handle, next remove the screws attaching the cord, and switch trim plate. The small screw and knob on the handle pivot must be removed to remove the switch trim piece - insert a flat screwdriver into the small slot in the plastic and pop the trim off to expose the rear motor shell screws. Remove the four screws holding the upper motor shell in place to expose the fan housing screws. Remove the five screws holding the fan housing in place, noting their positions. Pry the fan housing off to expose the fan. Hold the fan in place while turning the belt pulley CLOCKWISE to remove it. If the armature turns, it must be held in place with an open end wrench (about 9mm). There are flat spots on the armature just in front of the commutator bars. Pull or pry the fan and associated washer off the armature shaft. After replacing the fan and pulley, put a bead of silicon sealant on the fan housing and replace all parts in reverse order of removing.
Dec 01, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Motor is making a strange
Armature or fan in motor has gone bad. Replace motor.
May 06, 2010 | Electrolux Central Vacuum
Trying to replace fan on Kirby g5 but the whole thing keeps turning and I can't get it off, any suggestions?
The threads are left handed on the shaft. opposite than what everyone is used to. there are flat spots on the back of the motor armature where you can put a wrench to hold it from spinning.
Jan 03, 2010 | Kirby G5 Bagged Upright Vacuum
You really don't want to get into the vacuum. After you get in, there's not much that you can do other than look. If you really want to get in, there are two strips,one on each side of the cleaner under the rubber bumpers. The strips have to be removed by pulling off the bumper and pull them out the front of the vac.This is not easy. The bearings are not replaceable. If the armature is gone, you can have a armature and bracket kit installed instead of a new motor and save some money. The armature comes with the bearing pressed on the top.
Jan 07, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Kirby fan on motor
I am assuming that you are trying to remove the fan. On newer models there is a cut on the shaft (rear of the motor - next to comutator) that allows to use a wrench to hold the armature, it may be very similar on older models. maybe a hole instead of the cut... You would have to access the rear of the motor though. Let me know if you cant find it - I'll take one Heritage apart here in the shop and will see.
Good Luck
Oct 05, 2008 | Kirby Heritage II Vacuum
Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Jun 21, 2008 | Kirby Heritage II Vacuum
Take off the bottom plate, remove the screws for the motor and fan chamber, remove motor from fan housing, remove the nut for the fan. You may have to lock down the armature if the nut is too tight. Replace fan and reinstall motor into the fan housing and reinstall.
Apr 10, 2008 | Oreck XL2600 Vacuum
Kirby G4 Bagged Upright Vacuum Logo
112 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
